[mapserver-users] TIme support on mapserver 5.6.3, it's working?
rai 8 max1000 at gmail.com
Fri Jul 2 08:20:00 EDT 2010
> Could you provide an example URL you are using to test out the WMS-T?  I am
> using WMS-T on 5.6.3 without any known issues.  Please note that if your
> time table gets very large, you may hit this quirk:
I am using URL like:
http://mapserver-tutorial/cgi-bin/mapserv?map=/home/vbox/map_directory/tile_time_2.map&layer=radar&layer=time_idx_pg&mode=map&TIME=2004-01-01T10:10:00
It shows an image but always the first ->
/home/vbox/Downloads/animacio/sat1.tif , that have the timestamp: 2007-05-11
10:00Z
My table its very little, I was wrong about the version, is the 5.4.2, i'll
try to do the same with the 5.6 but it's very strange that any configuration
that I tried doesn't work.
need to be in the METADATA section of the "sat_w" layer.
I tried a lot of combinations, also with all the metadata in sat_w like
"official" tutorial
thanks a lot!
2010/7/1 Alexander Petkov <greenkov at gmail.com>
> On Thu, Jul 1, 2010 at 6:27 AM, rai 8 <max1000 at gmail.com> wrote:
> > Hello,
> > I've been working with mapserver to get a map with time support, time
>  > parameter, I followed the tutorial in documetation
> > http://mapserver.org/ogc/wms_time.html and this post
> http://osgeo-org.1803224.n2.nabble.com/Accessing-images-using-time-dimension-td1991324.html#a1991324
> > and I can't run the mapserver to change the image with a time parameter.
> > I test several configurations but any works, the last is the same like
> the
> > post in the maillist, this is what i've done:
> > in a postgis database
> > create table satellite (image_path text, image_time timestamp);
> > select AddGeometryColumn('satellite', 'the_geom', 4326, 'POLYGON', 2);
> > insert into satellite (image_path, image_time, the_geom)
> > values ('/home/vbox/Downloads/animacio/sat1.tif', '2007-05-11 10:00Z',
> > GeomFromText('POLYGON((-31.82 75.55, -31.82 26.5, 51.31 26.5,51.31 75.55,
> > -31.82 75.55))', 4326));
> > values ('/home/vbox/Downloads/animacio/sat2.tif', '2007-05-11 11:00Z',
> > and the map file:
> >  LAYER
> >     NAME    "time_w"
> >     TYPE    POLYGON
> >     STATUS    ON
> >     CONNECTIONTYPE  POSTGIS
> >     CONNECTION    "dbname=tile_index host=127.0.0.1 user=postgres
> > password=xxxxxx"
> >     DATA    "the_geom from satellite using unique oid using srid = 4326"
> >     METADATA
> >         "wms_title"    "time_index_w"
> >         "wms_srs"    "EPSG:4326"
> >         "wms_timeextent"    "2007-01-01/2007-12-31"
> >         "wms_timedefault"   "2007-05-11T11:00:00Z"
> >         "wms_timeitem"    "image_time" #a column in postgis table of type
> >     END
> >   END
> >   LAYER
> >     NAME    "sat_w"
> >     STATUS  ON
> >     TYPE    RASTER
> >     METADATA
> >         "wms_title"    "Satellite"
> >     END
> >     PROJECTION
> >       "init=epsg:4326"
> >     END
> >     TILEINDEX "time_w" # Layer name containing time index
> >     TILEITEM  "image_path" # DB column containing path to image
> >   END
> > anyone finds some error?
> > thanks
> The time-related metadata items:
> Alex
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100702/d3cdc76b/attachment.html
