[mapserver-users] adding a palette to a greytiff
michele pierri pierm4ci at yahoo.it
Wed Jul 7 16:58:50 EDT 2010
How I have to set EXTENT parameter? What are the correct value?
Can you take me an example?
Thanks a lot.Michele.
--- Mer 7/7/10, Alexander Petkov <greenkov at gmail.com> ha scritto:
Da: Alexander Petkov <greenkov at gmail.com>
Oggetto: Re: [mapserver-users] adding a palette to a greytiff
A: "michele pierri" <pierm4ci at yahoo.it>
Cc: mapserver-users at lists.osgeo.org
Data: Mercoledì 7 luglio 2010, 22:52
The first thing that I see is that the EXTENT needs to be corrected in your map file.
On Wed, Jul 7, 2010 at 2:47 PM, michele pierri <pierm4ci at yahoo.it> wrote:
This is what I request with a browser.http://localhost/cgi-bin/mapserv?map=/var/www/sviluppo/workshop-5.4/prova.map&mode=map
Thanks again,Michele.
Data: Mercoledì 7 luglio 2010, 22:28
Can you also include a sample request that gives you a blank map?
On Wed, Jul 7, 2010 at 1:57 PM, michele pierri <pierm4ci at yahoo.it> wrote:
Hi, thanks for help me.
1. Is your file indeed georeferenced?
Yes it is georeferenced.
2. The style definitions look good, the only thing I see missing are
the class names. Not sure if that matters if you don't display a
legend.How I have to modify the .map file for add this information? Can you write me an example?
3. Have you got the map file working without the class definitions?
I.E get a grayscale map?
If I write this file map I have always blank image:
MAP	NAME	"prova"
	CONFIG  "PROJ_LIB" "/usr/share/proj/"	STATUS ON	SHAPEPATH "./"	SIZE 494 531
	PROJECTION 		"init=epsg:4326"	END		EXTENT -154 -57 26 33	DEBUG 5
		WEB		IMAGEPATH
 "/var/www/sviluppo//workshop-5.4/tmp/"		IMAGEURL "/sviluppo/tmp/"	END
	LAYER
  		NAME "tif"		DATA "prova.tif"		STATUS ON		TYPE RASTER		OFFSITE 0 0 0
	ENDEND
4. Have you attempted to discover what is wrong by looking at the
mapserver log? You will
 need to enable logging in your map file.How I can enable it?
I have upload the image on another upload web service:http://www.megaupload.com/?d=K8SY5IP3
you can try this if you want.Or can you try with a your image?
Thanks again.Michele.
 2010, 21:29
For some reason I can;t get to the file you posted, so I have a few question.
legend.
mapserver log? You will need to enable logging in your map file.
Alex
On Wed, Jul 7, 2010 at 9:44 AM, michele pierri <pierm4ci at yahoo.it> wrote:
> Hi,
> I have this image: http://www.2shared.com/photo/Qu2cyRc2/prova.html
> I would visualize it with a colour scaled
 palette.
> I have write this file.map, but I receive only blank page.
> MAP
>     NAME    "prova"
>     STATUS ON
>     SHAPEPATH "./"
>     SIZE 494 531
>     PROJECTION
>         "init=epsg:4326"
>     END
>     DEBUG 5
>     WEB
>         IMAGEPATH "/var/www/sviluppo//workshop-5.4/tmp/"
>     END
>     LAYER
>           NAME
 "tif"
>         DATA "prova.tif"
>         STATUS ON
>         TYPE RASTER
>         OFFSITE 0 0 0
>         CLASSITEM "[pixel]"
>         CLASS
>             EXPRESSION ([pixel] >= 0 AND [pixel] < 10 )
>             STYLE
>                 COLOR 0 255 255
>             END
>         END
>         CLASS
>             EXPRESSION ([pixel] >= 10 AND [pixel] < 40)
    STYLE
>                 COLOR 0 255 0
>             END
>         END
>         CLASS
>             EXPRESSION ( [pixel] >= 40 AND [pixel] < 80)
>             STYLE
>                 COLOR 255 255 0
>             END
>         END
>         CLASS
>             EXPRESSION ([pixel] >= 80 AND [pixel] < 120)
>             STYLE
    COLOR 255 127 0
>             END
>         END
>         CLASS
>             EXPRESSION ([pixel] >= 120 AND [pixel] < 150)
>             STYLE
>                 COLOR 255 0 0
>               END
>         END
>         CLASS
>             EXPRESSION ([pixel] >= 150 AND [pixel] < 200)
>             STYLE
>                 COLOR 255 127 255
    END
>         END
>         CLASS
>             EXPRESSION ([pixel] >= 200 AND [pixel]<40)
>             STYLE
>                 COLOR 0 0 0
>               END
>         END
>     END
> END
> Can anyone help me please? I am sorry but I am a beginner.
> Thanks in advance,
> Michele.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100707/71121c46/attachment-0001.html
