[mapserver-users] adding a palette to a greytiff
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Jul 7 21:45:05 EDT 2010
I guess I'd recommend moving to the OL website and looking at their examples. They've done a WONDERFUL job of providing examples that
cover most typical (and a number of atypical) use cases- including basic MapServer.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of michele pierri [pierm4ci at yahoo.it]
Sent: Wednesday, July 07, 2010 5:02 PM
To: Lime, Steve D (DNR); Alexander Petkov; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] adding a palette to a greytiff
Thank you!
Now it works. Here there is my output example results: http://img413.imageshack.us/img413/7964/mapserv.gif
Now can I put this image on a background map? For example on openlayers map?
Thanks again,
Michele.
--- Mer 7/7/10, Lime, Steve D (DNR) <Steve.Lime at state.mn.us> ha scritto:
Da: Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
Oggetto: RE: [mapserver-users] adding a palette to a greytiff
A: "michele pierri" <pierm4ci at yahoo.it>, "Alexander Petkov" <greenkov at gmail.com>, "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Data: Mercoledì 7 luglio 2010, 23:41
The layer needs to be turned on. By default with the CGI all layers are turned off unless they are "STATUS DEFAULT". To fix, either:
1) set the layer "tif" status to DEFAULT or
2) change your call to the CGI to something like: http://localhost/cgi-bin/mapserv?map=/var/www/sviluppo/workshop-5.4/prova.map&mode=map&layer=tif
Steve
From: mapserver-users-bounces at lists.osgeo.org</mc/compose?to=mapserver-users-bounces at lists.osgeo.org> [mapserver-users-bounces at lists.osgeo.org</mc/compose?to=mapserver-users-bounces at lists.osgeo.org>] On Behalf Of michele pierri [pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it>]
Sent: Wednesday, July 07, 2010 4:20 PM
To: Alexander Petkov; mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] adding a palette to a greytiff
I have added this line in .map file:
CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
And this is the output:
[Wed Jul 7 23:18:21 2010].797918 CGI Request 1 on process 4712
[Wed Jul 7 23:18:21 2010].798507 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Jul 7 23:18:21 2010].798536 msDrawMap() total time: 0.000s
[Wed Jul 7 23:18:21 2010].805594 msSaveImage() total time: 0.007s
[Wed Jul 7 23:18:21 2010].805715 mapserv request processing time (loadmap not incl.): 0.008s
[Wed Jul 7 23:18:21 2010].805731 msFreeMap(): freeing map at 0x8dd72a0.
May be useful?
Thanks.
--- Mer 7/7/10, michele pierri <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it>> ha scritto:
Da: michele pierri <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it>>
Oggetto: Re: [mapserver-users] adding a palette to a greytiff
A: "Alexander Petkov" <greenkov at gmail.com</mc/compose?to=greenkov at gmail.com>>, mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org>
Data: Mercoledì 7 luglio 2010, 22:58
How I have to set EXTENT parameter? What are the correct value?
Can you take me an example?
Thanks a lot.
Michele.
--- Mer 7/7/10, Alexander Petkov <greenkov at gmail.com</mc/compose?to=greenkov at gmail.com>> ha scritto:
Da: Alexander Petkov <greenkov at gmail.com</mc/compose?to=greenkov at gmail.com>>
A: "michele pierri" <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it>>
Cc: mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org>
Data: Mercoledì 7 luglio 2010, 22:52
The first thing that I see is that the EXTENT needs to be corrected in your map file.
On Wed, Jul 7, 2010 at 2:47 PM, michele pierri <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it>> wrote:
This is what I request with a browser.
Thanks again,
Michele.
Data: Mercoledì 7 luglio 2010, 22:28
Can you also include a sample request that gives you a blank map?
On Wed, Jul 7, 2010 at 1:57 PM, michele pierri <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it><http://mc/compose?to=pierm4ci@yahoo.it>> wrote:
Hi, thanks for help me.
1. Is your file indeed georeferenced?
Yes it is georeferenced.
2. The style definitions look good, the only thing I see missing are
the class names. Not sure if that matters if you don't display a
legend.
How I have to modify the .map file for add this information? Can you write me an example?
3. Have you got the map file working without the class definitions?
I.E get a grayscale map?
If I write this file map I have always blank image:
MAP
NAME "prova"
CONFIG "PROJ_LIB" "/usr/share/proj/"
STATUS ON
SHAPEPATH "./"
SIZE 494 531
PROJECTION
"init=epsg:4326"
END
EXTENT -154 -57 26 33
DEBUG 5
WEB
IMAGEPATH "/var/www/sviluppo//workshop-5.4/tmp/"
IMAGEURL "/sviluppo/tmp/"
END
LAYER
NAME "tif"
DATA "prova.tif"
STATUS ON
TYPE RASTER
OFFSITE 0 0 0
END
END
4. Have you attempted to discover what is wrong by looking at the
mapserver log? You will need to enable logging in your map file.
How I can enable it?
I have upload the image on another upload web service:
http://www.megaupload.com/?d=K8SY5IP3
<http://www.megaupload.com/?d=K8SY5IP3>you can try this if you want.
Or can you try with a your image?
Thanks again.
Michele.
--- Mer 7/7/10, Alexander Petkov <greenkov at gmail.com</mc/compose?to=greenkov at gmail.com><http://mc/compose?to=greenkov@gmail.com>> ha scritto:
Da: Alexander Petkov <greenkov at gmail.com</mc/compose?to=greenkov at gmail.com><http://mc/compose?to=greenkov@gmail.com>>
A: "michele pierri" <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it><http://mc/compose?to=pierm4ci@yahoo.it>>
Cc: mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org><http://mc/compose?to=mapserver-users@lists.osgeo.org>
Data: Mercoledì 7 luglio 2010, 21:29
For some reason I can;t get to the file you posted, so I have a few question.
legend.
Alex
On Wed, Jul 7, 2010 at 9:44 AM, michele pierri <pierm4ci at yahoo.it</mc/compose?to=pierm4ci at yahoo.it><http://mc/compose?to=pierm4ci@yahoo.it>> wrote:
> Hi,
> I have this image: http://www.2shared.com/photo/Qu2cyRc2/prova.html
> I would visualize it with a colour scaled palette.
> I have write this file.map, but I receive only blank page.
> MAP
> NAME "prova"
> STATUS ON
> SHAPEPATH "./"
> SIZE 494 531
> PROJECTION
> "init=epsg:4326"
> END
> DEBUG 5
> WEB
> END
> LAYER
> NAME "tif"
> DATA "prova.tif"
> STATUS ON
> TYPE RASTER
> OFFSITE 0 0 0
> CLASSITEM "[pixel]"
> CLASS
> EXPRESSION ([pixel] >= 0 AND [pixel] < 10 )
> STYLE
> COLOR 0 255 255
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 10 AND [pixel] < 40)
> STYLE
> COLOR 0 255 0
> END
> END
> CLASS
> EXPRESSION ( [pixel] >= 40 AND [pixel] < 80)
> STYLE
> COLOR 255 255 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 80 AND [pixel] < 120)
> STYLE
> COLOR 255 127 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 120 AND [pixel] < 150)
> STYLE
> COLOR 255 0 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 150 AND [pixel] < 200)
> STYLE
> COLOR 255 127 255
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 200 AND [pixel]<40)
> STYLE
> COLOR 0 0 0
> END
> END
> END
> END
> Can anyone help me please? I am sorry but I am a beginner.
> Thanks in advance,
> Michele.
-----Segue allegato-----
mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org></mc/compose?to=mapserver-users at lists.osgeo.org</mc/compose?to=mapserver-users at lists.osgeo.org>>
