[mapserver-users] WFS Server does not support VERSION 1.1.0
Daniel Morissette
dmorissette at mapgears.com
Thu Jul 8 10:49:17 EDT 2010
Chris Green wrote:
> A correction from my ISP: now they say that the Linux installation is
> Fedora Core 7. Could this be the explanation of my problem?
Double-check the mapserv version that you are using through the Web.
Even if you installed FGS, maybe you're not using the copy of mapserv
you think you are.
Use a URL like the following:
http://your.server.com/cgi-bin/mapserv?test=1
And then do a "View Source"... you will see the MapServer version in the
HTML source.
Daniel Morissette
http://www.mapgears.com/
