[mapserver-users] WFS Error "column = 1" on msPostGISLayerGetShape
Andy Colson
andy at squeakycode.net
Fri Jul 9 12:19:48 EDT 2010
Oh... Yeah... I should pay more attention to the actual message:
> HINT: No operator matches the given name and argument type(s). You might
> need to add explicit type casts.
This was not a "field not found" message, I fixed the wrong thing..
oops. Good catch Carlos.
-Andy
On 7/9/2010 11:15 AM, Carlos Ruiz wrote:
> The cell_id column is of the integer type ? or character varying type ?
> It must be integer to be able to
> compare.
> IC Carlos Ruiz
> *From:* Andy Colson <andy at squeakycode.net>
> *To:* Benoit PESTY <tchule at hotmail.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Fri, July 9, 2010 10:23:39 AM
> *Subject:* Re: [mapserver-users] WFS Error "column = 1" on
> On 7/9/2010 10:16 AM, Benoit PESTY wrote:
> > Hello,
> > I have a problem configuring a WFS Service.
> > My layer is defined like this:
> > LAYER
> > NAME " forest_plot_layer"
> > TYPE POLYGON
> > STATUS ON
> > METADATA
> > WFS_TITLE "Forest Plots"
> > "gml_include_items" "all"
> > "gml_featureid" "cell_id"
> > END
> > DUMP TRUE
> > CONNECTIONTYPE postgis
> > CONNECTION xxxxxxxxxx
> > DATA "the_geom FROM forest_plot_layer"
> > CLASS
> > NAME "Forest Plot"
> > STYLE
> > SIZE 3
> > COLOR 0 255 0
> > OUTLINECOLOR 0 255 0
> > END
> > END
> > PROJECTION
> > "init=epsg:3035"
> > END
> > END
> > And I have the follwing error :
> > [Tue Jul 6 18:49:16 2010].228958 msPostGISLayerGetShape(): Query error.
> > Error (ERROR: operator does not exist: character varying = integer LINE
> > 1: ...l_id" from forest_plot_layer where "cell_id" = 1
> > My "forest_plot_layer" table only has a "cell_id" column which is the PK
> > and a "the_geom" column.
> > The WMS service works correctly.
> > Does anyone have an idea?
> > Thanks,
> This: "gml_featureid" "cell_id"
> Seems to be the culprit. I'm not sure what that does, if you dont need
> it, delete it.
> If you do need it, then I'd guess changing your sql to this would help:
> DATA "the_geom FROM (select cell_id, the_geom from forest_plot_layer) as
> subq"
> ... unrelated, I see you dont have "using unique" on your DATA line... I
> believe it'll speed things up if you use it. (although I have never
> actually tested the claim).
> from: http://mapserver.org/input/vector/postgis.html
> -Andy
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
