[mapserver-users] WFS Server does not support VERSION 1.1.0
Chris Green
chris.green at ibstv.co.uk
Fri Jul 9 18:05:07 EDT 2010
Daniel
Thank you I really appreciate you taking the time to explain that. I have
followed your instructions and the upgrade seems to have installed OK (both
mapserver-base 5.6.4 and mapserver-php 5.6.4). However when I try running my
application I get an error log of:
"/opt/fgs/www/cgi-bin/mapserv: /lib/libc.so.6: version `GLIBC_2.7' not found
(required by /opt/fgs/lib/libjpeg.so.7)"
Is GLIBC_2.7 supposed to be in Mapserver 4.6.4?
Chris
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Daniel
Morissette
Sent: 09 July 2010 21:20
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WFS Server does not support VERSION 1.1.0
Chris Green wrote:
> Daniel
> You hit the nail on the head...I had blindly followed the example and
> downloaded Mapserver 5.0.2. I suppose that does not support WFS version
> 1.1.0, which caused my problem.
> It should have been simple to re-download Mapserver 5.6.3, but actually I
> found that all attempts to download using:
> wget http://dl.maptools.org/dl/fgs/releases/1.0/1.0.0/self-installers/
> fgs-mapserver_basic_5.6.3-fgs_9.5-linux-i386.bin
> failed with a 404 page not found error. Probably caused by my embarrassing
> lack of Linux knowledge - could I trouble you to guide me one more time to
> solve how to download the latest file please?
The latest release of FGS is 9.5. The available installers are at
http://dl.maptools.org/dl/fgs/releases/9.5/self-installers/
So in your case you could use
wget
http://dl.maptools.org/dl/fgs/releases/9.5/self-installers/fgs-mapserver_bas
Note that we just released MapServer 5.6.4 this morning, so after
installing FGS you should upgrade your mapserver version to 5.6.4. I
haven't done this in a while myself, but if I'm not mistaken, according
to http://www.maptools.org/fgs/index.phtml?page=install.html you should
have to do something like the following:
cd /path/to/fgs
. setenv.sh
fgs stop
fgs force-install mapserver-base:5.6.4
fgs force-install mapserver-php:5.6.4
fgs start
If the command above does not find the package source, you may have to
specify the URL to get it from as the last argument, e.g.:
http://dl.maptools.org/dl/fgs/releases/9.5/modules/
Daniel
Daniel Morissette
http://www.mapgears.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
