[mapserver-users] UMN + Postsgis, features skipped
Carlos Ruiz boolean10001 at yahoo.com
Mon Jul 12 10:44:24 EDT 2010
Andreas,
First, try to run SELECT DISTINCT(type) FROM
"av_mopublic"."land_cover_lcsurface" to ensure that all the
types that you're classifying exists. I know this sounds silly but we must check
if the type column contains
all the types you're looking for.
When some features are missing, it means that the expression type doesn't exists
and then, it's not
rendered.
I've noticed that expressions are case sensitive, and sometimes, it doesn't
works with special characters,
maybe this could be happening too.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Mon, July 12, 2010 7:58:16 AM
Subject: [mapserver-users] UMN + Postsgis, features skipped
Hi all,
I have troubles with the UMN/Postgis combo. When I just draw the layer
with a single class, it draws fine, but as soon as I use classification
with an EXPRESSION (simple string comparison), a lot of features are
skipped.
Attached I am sending a mapfile with just one class (buildings from a
landcover table). Most buildings are skipped, only a few are drawn.
I have no idea why.
The same table draws fine without problems in QGIS.
Any idea why the classification is skipping many features?
Thanks a lot,
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100712/37338e9b/attachment.html
