[mapserver-users] rendering difference between 5.6.3 and 5.6.4
Christy Nieman cnieman at dmsolutions.ca
Tue Jul 13 10:08:01 EDT 2010
Checked the mapserver binaries - both have AGG (and since both using the
same mapfile, both have the same output format specified).  Will work on
getting a sample mapfile that demonstrates this.
On 07/13/2010 10:05 AM, Andy Colson wrote:
> On 7/13/2010 8:46 AM, Christy Nieman wrote:
>> Hi,
>> I've just compiled mapserver 5.6.4 in an FGS enviromnment, and when I
>> rendered a map I noticed that it was taking a very long time. Once the
>> image was displayed, it seemed that the largest scale class for each
>> layer had been used for a rather small scale map. I've attached a 5.6.3
>> and 5.6.4 example of the same mapfile. Is there something that I haven't
>> changed that's needed for 5.6.4? I recall reading that 5.6.4 wouldn't
>> require any modifications for users?
>> Thanks,
>> Christy
> You didn't by chance use GD to render the first and AGG for the
> second?  Perhaps you requested AGG in 5.4.3 but it was not compiled
> in, but it is now?
> -Andy
