[mapserver-users] Question about oracle spatial configuration
change
Alan Boudreault
aboudreault at mapgears.com
Wed Jul 14 09:57:01 EDT 2010
Normally, you shouldn't have to change anything else. Have you tried to
connect to the DB with your new user from the oracle sqlplus and did a "select
* from <your_table_name>" ?
Thanks,
Alan
On July 14, 2010 08:07:05 am David Alda Fernandez de Lezea wrote:
> Hi list,
> We were working with mapserver 5.6.1 and oracle spatial, and we have change
> the user (the new one has less privileges - it cannot modify anything
> stored in the DB) that connects to oracle spatial, and now we cannot
> connect to the layers stored in oracle. We get the following message:
> [Wed Jul 14 14:01:29 2010].755000 CGI Request 1 on process 2648
> [Wed Jul 14 14:01:30 2010].380000 msOracleSpatialLayerGetItems(): Query
> error. Cannot retrieve column list [Wed Jul 14 14:01:30 2010].380000
> msDrawMap(): Image handling error. Failed to draw layer named
> 'provincias'. [Wed Jul 14 14:01:30 2010].380000 mapserv request processing
> time (msLoadMap not incl.): 0.625s [Wed Jul 14 14:01:30 2010].380000
> msFreeMap(): freeing map at 019AB590. [Wed Jul 14 14:01:32 2010].520000
> CGI Request 1 on process 1924
> [Wed Jul 14 14:01:32 2010].661000 msOracleSpatialLayerGetItems(): Query
> error. Cannot retrieve column list [Wed Jul 14 14:01:32 2010].661000
> 'provincias'. [Wed Jul 14 14:01:32 2010].661000 mapserv request processing
> time (msLoadMap not incl.): 0.141s [Wed Jul 14 14:01:32 2010].661000
> msFreeMap(): freeing map at 019AB590. [Wed Jul 14 14:01:33 2010].36000 CGI
> Request 1 on process 2408
> [Wed Jul 14 14:01:33 2010].161000 msOracleSpatialLayerGetItems(): Query
> error. Cannot retrieve column list [Wed Jul 14 14:01:33 2010].161000
> 'provincias'. [Wed Jul 14 14:01:33 2010].161000 mapserv request processing
> time (msLoadMap not incl.): 0.125s [Wed Jul 14 14:01:33 2010].161000
> msFreeMap(): freeing map at 019AB590. [Wed Jul 14 14:01:33 2010].505000
> CGI Request 1 on process 2064
> [Wed Jul 14 14:01:33 2010].677000 msOracleSpatialLayerGetItems(): Query
> error. Cannot retrieve column list [Wed Jul 14 14:01:33 2010].677000
> 'provincias'. [Wed Jul 14 14:01:33 2010].677000 mapserv request processing
> time (msLoadMap not incl.): 0.172s [Wed Jul 14 14:01:33 2010].677000
> msFreeMap(): freeing map at 019AB590. [Wed Jul 14 14:01:33 2010].989000
> CGI Request 1 on process 3216
> [Wed Jul 14 14:01:34 2010].130000 msOracleSpatialLayerGetItems(): Query
> error. Cannot retrieve column list [Wed Jul 14 14:01:34 2010].130000
> 'provincias'. [Wed Jul 14 14:01:34 2010].130000 mapserv request processing
> time (msLoadMap not incl.): 0.141s [Wed Jul 14 14:01:34 2010].130000
> Do we have to refresh something or do somethign else?
> Layer config:
> CONNECTIONTYPE oraclespatial
> CONNECTION "newuser/newpass at ORA10GEX"
> If configure the layer with the old user, it works.
> Thanks.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> ······· Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
> ······· email: dalda at ikt.es web: www.ikt.es
> ········ _______________________________________________
> mapserver-users at lists.osgeo.org
Alan Boudreault
Mapgears
http://www.mapgears.com
