[mapserver-users] RE: multiple map layers with different scales
easyl
thlin.box at gmail.com
Fri Jul 16 04:51:33 EDT 2010
does it mean that I should also always give "SCALEDENOM" in the CGI request?
I tries to set MAX/MINSCALEDENOM for each layer and to use SCALEDENOM in CGI
request.
But it works just other than what I expect.
The maps (layers) what I have have a real map scale value (e.g. 1:250,000).
The maps have different detail according to different scales.
1) At first I tried WITHOUT MAX/MINSCALEDENOM
in mapfile:
LAYER
NAME LAYER_SCALE_1500000
STATUS ON
TYPE POLYGON
#MINSCALEDENOM 350001
CONNECTIONTYPE OGR
CONNECTION "layer.shp"
DATA "layer"
END
and with CGI request:
/cgi-bin/mapserv?LAYERS=ALL&MODE=MAP&MAP=/my.map&MAPXY=10+50&SCALEDENOM=1
The map is shown and it looks OK.
then I tried with this CGI request:
/cgi-bin/mapserv?LAYERS=ALL&MODE=MAP&MAP=/my.map&MAPXY=10+50&SCALEDENOM=20
then the map is still shown but its size is decreased (it should be 20x
smaller than that with SCALEDENOM=1)
does SCALEDENOM mean the "actual" map scale or is it just for mapserver to
zoom in/out?
2) if I try using the CGI request with the "actual" map scale:
/cgi-bin/mapserv?LAYERS=ALL&MODE=MAP&MAP=/my.map&MAPXY=10+50&SCALEDENOM=1500000
then the map will be so small that it will be never shown or seen!
and it would make no sense to define MAX/MINSCALEDENOM for layers with
actual scale value.
LAYER
STATUS ON
TYPE POLYGON
CONNECTIONTYPE OGR
DATA "layer"
END
How should I correctly use those parameters?
must I always use MAPXY with SCALEDENOM in CGI request?
Can I define MAPEXT with SCALEDENOM to defined explicit bounding box? how
about MAPSIZE or BUFFER?
I want to use different scale value to show different map layer, and the
zoom (in/out) effect is somehow done in client application.
thanks for your help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/multiple-map-layers-with-different-scales-tp5292120p5301056.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
