[mapserver-users] tiff image drawing error
YAMADA,Yasuharu
yamaday at affrc.go.jp
Fri Jul 16 06:30:51 EDT 2010
Dear Rahkonen Jukka,
Rahkonen Jukka wrote:
> Hi,
> Please send what does gdalinfo reports with command
> gdalinfo /opt/geoweb/maps/snapout2.tif
> -Jukka Rahkonen-
The following information was received from the system.
[geoweb at localhost ~]$ gdalinfo /opt/geoweb/maps/snapout2.tif
Driver: GTiff/GeoTIFF
Files: /opt/geoweb/maps/snapout2.tif
Size is 829, 660
Coordinate System is:
PROJCS["WGS 84 / UTM zone 53N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",135],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32653"]]
GeoTransform =
874766.4700993124, 202.4737334795803, 12.20997246250808
4156085.1049555, 13.00152125831844, -202.530619799912
Metadata:
TIFFTAG_XRESOLUTION=300
TIFFTAG_YRESOLUTION=300
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 874766.470, 4156085.105) (139d14'15.11"E, 37d28'32.49"N)
Lower Left ( 882825.052, 4022414.896) (139d15'39.67"E, 36d16'14.86"N)
Upper Right ( 1042617.195, 4166863.366) (141d 8'5.84"E, 37d29'21.16"N)
Lower Right ( 1050675.777, 4033193.157) (141d 7'43.29"E, 36d17'11.34"N)
Center ( 962721.124, 4094639.131) (140d11'26.37"E, 36d53'3.53"N)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
Yasuharu Yamada
