[mapserver-users] Re: multiple map layers with different scales
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jul 20 13:48:05 EDT 2010
This is still confusing MapServer. Remember the map size is fixed, so you're asking to do contradictory things, either a map using:
- mapxy and buffer OR
- mapxy and scaledenom
You can't do both...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of easyl
Sent: Tuesday, July 20, 2010 8:31 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Re: multiple map layers with different scales
then I tried
mapserv?map=mapfile.map
&layers=ALL
&mode=MAP
&mapxy=12+45
&buffer=30
&mapsize=500+500
&SCALEDENOM=45000
The mapserver just calculated out an extreme large extent and the region
where I am interested in is rendered as small as just one point. (larger
SCALEDENOM -> larger extent)
According to http://mapserver.org/cgi/controls.html the mapsize or imgsize
should only affect the pixel size of output image. The "buffer" should work
with mapxy for limiting map extent. But changing the "buffer" in above
example did not affect the map extent.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/multiple-map-layers-with-different-scales-tp5292120p5316617.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
