[mapserver-users] [Info] S-57 nautical map on MapServer
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jul 23 09:52:33 EDT 2010
I may have missed this in your explanation, but for the record MapServer
can read and display S-57 data in its raw format, through the OGR
library (CONNECTIONTYPE OGR)...meaning no conversion is necessary.
And a shameful plug: in our upcoming MapServer workshop at FOSS4G in
Barcelona we will demonstrate this
(http://2010.foss4g.org/workshop08.php). :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
easyl wrote:
> Since several months I was looking for an good example or tutorial for
> rendering S-57 nautical charts on MapServer.
> After searching without any success I tried to build up my first map with
> limit knowledge.
> IMO, the most hardest part is how to render them with S-52 style standard.
> (The project http://www.opencpn.org/ has done a really good work to render
> nautical map in an application.)
> Some resource:
> http://home.gdal.org/projects/s57/index.html
> http://grass.osgeo.org/wiki/S-57_data
> http://www.s-57.com/
> Here is a short description of what I have done.
> 1) Conver S-57 (*.000) files into shapefiles by using ogr2ogr.
> An S-57 file is split into several shapefiles;
> Each shapefile contains single one layer of single geometry type.
> For example:
> src.000 ------ DEPARE ------> Area (a shapefile)
> + +--> Line (a shapefile)
> +-- (other layer) ......................... (a
> shapefile)
> Here is the ogr2ogr commands
> > ogr2ogr -skipfailure -append -f "ESRI Shapefile" output/DEPARE/A
> src.000 -nlt POLYGON DEPARE
> > ogr2ogr -skipfailure -append -f "ESRI Shapefile" output/DEPARE/L
> src.000 -nlt LINESTRING DEPARE
> The SOUNDG layer must be converted with special care.
> > export OGR_S57_OPTIONS="SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON"
> > ogr2ogr -skipfailure -append -f "ESRI Shapefile" output/SOUNDG/P src.000
> -nlt POINT SOUNDG
> 2) Construct mapfile
> 2.1) Generally there are (at least) two things to take care: scale and
> layer priority.
> S-57 data may have different scale value and overlap with each
> other.
> Moreover, a S-57 data may not have a rectangle extent.
> For those reasons, I construct mapfile with the following manner:
> Sort layers after scale value, then layer priority.
> Group them if necessary.
> MAP
> LAYER
> // scale: 1:100,000
> // priority: low
> CONNECTION "shapefile/100000/DEPARE/A/DEPARE.shp"
> DATA "DEPARE"
> GROUP "DEPARE"
> END
> LAYER
> // scale: 1:100,000
> // priority: high
> CONNECTION "shapefile/100000/LIGHTS/P/LIGHTS.shp"
> DATA "LIGHTS"
> GROUP "LIGHTS"
> END
> LAYER
> // scale: 1:10,000
> // priority: low
> CONNECTION "shapefile/10000/DEPARE/A/DEPARE.shp"
> DATA "DEPARE"
> GROUP "DEPARE"
> END
> LAYER
> // scale: 1:10,000
> // priority: high
> CONNECTION "shapefile/10000/LIGHTS/P/LIGHTS.shp"
> DATA "LIGHTS"
> GROUP "LIGHTS"
> END
> END
> 2.2) apply style. It is the hardest part.
> Here I give abother two examples.
> LAYER
> NAME DEPARE_A_1500000_1
> GROUP "DEPARE"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "shapefile/1500000/DEPARE/A/DEPARE.shp"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> PROCESSING "LABEL_NO_CLIP=ON"
> DATA "DEPARE"
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
> CLASSITEM DRVAL1
> CLASS
> EXPRESSION ([DRVAL1] < 3)
> STYLE
> COLOR 115 182 239
> END
> END
> CLASS
> EXPRESSION ([DRVAL1] >= 3 && [DRVAL1] < 8)
> STYLE
> COLOR 156 198 247
> END
> END
> CLASS
> EXPRESSION ([DRVAL1] >= 8)
> STYLE
> COLOR 214 235 239
> END
> END
> END
> LAYER
> NAME LIGHTS_P_1500_1
> GROUP "LIGHTS"
> STATUS ON
> TYPE POINT
> #MAXSCALEDENOM 1501
> CONNECTIONTYPE OGR
> CONNECTION "shapefile/1500/LIGHTS/P/LIGHTS.shp"
> DATA "LIGHTS"
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
> CLASSITEM COLOUR
> CLASS
> EXPRESSION ([COLOUR] == 3)
> STYLE
> COLOR 255 0 0
> SIZE [VALNMR]
> OPACITY 50
> OUTLINECOLOR 0 0 0
> END
> END
> CLASS
> EXPRESSION ([COLOUR] == 4)
> STYLE
> COLOR 0 255 0
> SIZE [VALNMR]
> OPACITY 50
> OUTLINECOLOR 0 0 0
> END
> END
> END
> Here is the result:
> http://osgeo-org.1803224.n2.nabble.com/file/n5329589/s57MS.png
> http://osgeo-org.1803224.n2.nabble.com/file/n5329589/s57MS.PNG s57MS.PNG
> Of course, it needs still a lot of symbols, color encoding, customized
> style after standards ....
> I have wrote some script to automatically convert S-57 files and construct
> mapfile (manually writing a mapfile for 100+ layers from 20+ S-57 files is
> not practical...). If anyone has interest, I can share them or even make a
> project to let everyone contribute.....
> Now the task to be done is to encode every possible style in
> mapfile............................:(
> Any suggestion is welcome!
