[mapserver-users] RE: CLASS EXPRESSION regex help?
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Jul 23 11:01:29 EDT 2010
Hi Johan: Are you looking for just two classes, one for records that start with "LADE" and another for everything else? If so you can just omit the expression from the second class and it will function as a default class so everything that doesn't match the first will be assigned the second. It's faster to execute than trying to expressly define a second regex. Doesn't solve the regex error but then again you may not need to.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Johan Forsman
Sent: Friday, July 23, 2010 9:20 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] CLASS EXPRESSION regex help?
All:
Regex neophyte, using MS 5.4.2 in FGS on Ubuntu Server 9.10, I wish to render two classes based on content in a PostGIS field.
For the first CLASS I want all records that start with "LADE", and using
NAME "LADE"
EXPRESSION /^LADE.*/
appears to return the expected records.
However, for the second CLASS I want all records that DO NOT start with "LADE", but using
NAME "Other"
EXPRESSION /^(?!LADE).*/
does not return any records and the log contains
msEvalExpression() error: Regular expression error. Invalid regular expression.
Examples out in the ether all indicate that this "negative lookahead" is supposed to do exactly what I want.
What am I doing wrong in this instance?
Thanks!
/Johan.
Johan Forsman
Geologist
Safe Drinking Water Program
Louisiana Department of Health and Hospitals
Office of Public Health
Telephone: 225.342.7309
Telefax: 225.342.7303
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
