[mapserver-users] shapefile error only when zoomed out
Mon Jul 26 15:25:30 EDT 2010
Wendell Turner wrote:
> Why would a shapefile only display when the map display is
> zoomed in?
> When zoomed in, the image displays correctly.  When zoomed
> out, it gets this:
>   msDrawMap(): Image handling error. Failed to draw
>   layer named 'tfr'.; msDrawShape() General error
>   message.  Only polygon shapes can be drawn using
>   a POLYGON layer definition.
> shpdump shows this:
>   Shapefile Type: Polygon   # of Shapes: 2
>   Shape:1 (Polygon)  nVertices=0, nParts=0
>     Bounds:(         nan,         nan, 0, 0)
>         to (         nan,         nan, 0, 0)
> Is that a problem?  If so, is there a way of removing that
> shape (possibly using gdal)?
Wendell,
Something like the following might discard a particular shape:
   ogr2ogr out.shp in.shp -where "OGR_FID != 1"
The OGR_FID should be the same as the shape id reported by shpdump.
The shape in question is likely getting translated as something
not polygon-like whenever the view includes "0,0".
Best regards,
