[mapserver-users] Raster data performance
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Jul 28 10:09:53 EDT 2010
I don't know anything about your work flow, but if possible, you could add a pre-processing step where you use a script to read your text file and pre-classify the data. You would end up with integers representing each class as 'cell' values.
Instead of :
EXPRESSION([pixel] >= -4 AND [pixel] < -3)
You could have: EXPRESSION "2"
Or
EXPRESSION /2/
Matching a single string should be the fastest expression to evaluate.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tobias Weiß
Sent: Wednesday, July 28, 2010 8:25 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Raster data performance
Hi Alex,
I tried some of the performance tips you mentioned, e.g. converted the .txt to a tiled TIFF to optimize performance. I can not see significant changes in rendering speed.
gdal_translate -co TILED=YES input.txt output.tif
The major brake still is the expression stuff. I really wonder what makes this task so time-consuming, it should not be more than a simple comparison.
Do you have experiences with this issue? Or do I have to live with this constraint?
Best, Tobi
Am 28.07.10 14:27, schrieb Alexandre Dube:
Hi Tobi,
The following documentation topics about raster might help :
http://mapserver.org/input/raster.html#rasters-and-tile-indexing
http://mapserver.org/input/raster.html#raster-display-performance-tips
and about expressions :
http://mapserver.org/mapfile/expressions.html
The string comparison type is the fastest, so you could try define more classes but using string comparison to see if it gets faster. Also, a good performance tip is to put your most frequent classes types on top first. For example, if 80% of your data has "pixel = -3" then put it on top.
Kind regards,
Alexandre
On 10-07-28 04:54 AM, Tobias Weiß wrote:
Hello list,
this is my first email to this list. I am working with MapServer, OpenLayers & TileCache for almost 1 year now and the tools are really working great together, when everything is configured correctly ;-)
At the moment I´m facing a performance problem with raster data that serves as input data to render my map tiles. The spatial resolution of this raster data is 720 (rows) x 360 (cols) and it is stored in a simple .txt file (The size of the file is around 2 MB). I use TileCache to prerender maptiles for different zoom levels that are later displayed in a web application using OpenLayers.
I discovered, that the rendering speed of MapServer seems to mainly depend on how many different classes I define within my mapfile, meaning how many expressions MapServer has to evaluate during the rendering process. Without any classes MapServer the rendering speed is really fast, the more classes I use the slower it gets. With e.g. 10 different classes defining 10 different styles / pixel colors the rendering time for one tile can increase up to 60 sec.
CLASS
EXPRESSION ([pixel] >= -4 AND [pixel] < -3)
STYLE
COLOR 69 117 180
END
END
While working with shape files I haven´t had this problems and prerendering map tiles was really fast. With raster data the rendering time for one map and 5 different zoom levels can take up to several hours and almost overburdens my CPU.
Can anybody give me a hint how I could improve this?
Best, Tobi
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alexandre Dubé
Mapgears
www.mapgears.com<http://www.mapgears.com>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100728/326002da/attachment.html
