[mapserver-users] ogr connection failed
Murat Beyhan
beyhan at deprem.gov.tr
Fri Jul 30 10:43:40 EDT 2010
Hi All,
I have installed rpm package of Mapserver 5.6.3
adn I have installed gdal 1.7.2 by using tar.gz file
when I attempt to open map file from webpage I faced the following error
message
msDrawMap(): Image handling error. Failed to draw layer named 'Dhuman'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
`Dhuman'. Failed to open datasource
`MYSQL:turkey,user=root,password=mysqlpass,host=localhost,port=3306,tables=d_damage m_village'.
but when I use terminal for ogrinfo I can connect to database
successfully
What is wrong could you help me please
[murat at sakura cgi-bin]$ ogrinfo
"MYSQL:turkey,user=root,password=mysqlpass,host=localhost,port=3306,tables=d_pgadata"
INFO: Open of
`MYSQL:turkey,user=root,password=mysqlpass,host=localhost,port=3306,tables=d_pgadata'
using driver `MySQL' successful.
1: d_pgadata (None)
or
"MySQL:testogr,user=root,password=mysqlpass"
INFO: Open of `MySQL:testogr,user=root,password=mysql_123'
1: deniz (Polygon)
2: il_merkezleri (Point)
3: il_sinirlari (Polygon)
4: ilce_merkezleri (Point)
5: ilce_sinirlari (Polygon)
6: iller (Polygon)
7: iller_sil (Polygon)
8: komsular (Polygon)
these works fine.
ogr also support these formats
[murat at sakura cgi-bin]$ ogrinfo --formats
Supported Formats:
-> "ESRI Shapefile" (read/write)
-> "MapInfo File" (read/write)
-> "UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "BNA" (read/write)
-> "CSV" (read/write)
-> "GML" (read/write)
-> "GPX" (read/write)
-> "KML" (read/write)
-> "GeoJSON" (read/write)
-> "GMT" (read/write)
-> "SQLite" (read/write)
-> "ODBC" (read/write)
-> "PGeo" (readonly)
-> "OGDI" (readonly)
-> "MySQL" (read/write)
-> "PCIDSK" (readonly)
-> "XPlane" (readonly)
-> "AVCBin" (readonly)
-> "AVCE00" (readonly)
-> "DXF" (read/write)
-> "Geoconcept" (read/write)
-> "GeoRSS" (read/write)
-> "GPSTrackMaker" (read/write)
-> "VFK" (readonly)
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
