[mapserver-users] Styling a mapfile with SLD?
paalkr
pal.kristensen at statkart.no
Tue Jun 1 10:56:09 EDT 2010
Hi all!
I'm trying to sett up a MapService that uses OGC SLD to override the regular
MapServer rendering rules (classes and styles). For some reason MapServer
does not seem to pick up the SLD, because the resulting map uses the default
drawing rules defined in the map-file rather then the SLD.
And BTW, is it possible to assign a SLD to a layer internally in a map-file,
or do I need to provide the SLD as a parameter in the WMS GetMap request?
The layer in the mapfile looks like this:
LAYER
NAME "PolbndA"
TYPE POLYGON
#TYPE LINE
STATUS OFF
DEBUG 5
MAXSCALEDENOM 1900000
CONNECTIONTYPE postgis
CONNECTION "host=xx port=5432 dbname=xx password=xx user=xx"
DATA "shape from euroerm.polbnda USING UNIQUE objectid USING
SRID=4326"
PROCESSING "CLOSE_CONNECTION=DEFER"
METADATA
"wms_title" "Administrativie area"
"wms_extent" "-15 28 47 82"
#"wms_sld_url" "http://www.geonorge.no/styles/erm/erm_ms_22_ah.xml"
#"wms_sld_body" "AUTO"
END
PROJECTION
"init=epsg:4326"
END
#LABELITEM "f_code"
CLASSITEM "f_code"
CLASS
NAME "F_CODE"
STYLE
OUTLINECOLOR 255 100 0
SIZE 2
END
LABEL
COLOR 0 0 0
FONT verdana
TYPE TRUETYPE
SIZE 10
PARTIALS false
POSITION lc
END
END
END
The corresponding SLD document that I try to apply:
<?xml version="1.0" encoding="utf-8"?>
PolbndA
erm:Style1
Default Styler
PolbndA
title
abstract
Administrative Area
Administrative Area
f_code
FA001
#FFFFE6
1
Regards,
Pål Kristensen
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Styling-a-mapfile-with-SLD-tp5126372p5126372.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100601/68917d64/attachment.html
