[mapserver-users] MapScript resultsGetShape confusion
Daniel Morissette
dmorissette at mapgears.com
Tue Jun 1 17:02:35 EDT 2010
Christian Jauvin wrote:
> I did what you suggested, and added:
> CONFIG "MS_ERRORFILE" "<error file>"
> CONFIG "CPL_DEBUG" "ON"
> DEBUG 5
Did you also include DEBUG 5 inside the POSTGIS layer itself?
> to my mapfile, and performed my query again. It generated a very long
> file (200K+ lines!) with only two types of line:
> [Tue Jun 1 14:36:01 2010].765230 getSymbol(): Symbol definition
> error. Parsing error near (null):(line 208)
> [Tue Jun 1 14:36:01 2010].777963 msPostGISLayerResultsGetShape called
> for record = 338
200k times the same message sounds like an infinite loop of some sort.
Perhaps look at the first few lines of debug/error messages. There may
be a different message that would have been output *before* entering the
infinite loop and that could give a hint about what is happening. Just a
guess... can't do much more from here.
What is the last version that worked fine? 5.6.2?
Daniel
Daniel Morissette
http://www.mapgears.com/
