[mapserver-users] numeric label without decimal ?
Carlos Ruiz
boolean10001 at yahoo.com
Fri Jun 4 11:04:33 EDT 2010
Tonton,
This is because de data domain,there's no way to apply a format with the LABEL tag, you have to change the
data domain from the data source directly
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Fri, June 4, 2010 8:05:30 AM
Subject: [mapserver-users] numeric label without decimal ?
hello
i use shapefile to render a map in wms layer.
it is working good but ...
the column i use TXT have number ( 12 30 255 etc...)
so i see with 10 digits after the point ( 12.00000000 30.000000000 255.000000000 etc...)
if anybody know how to set that my label was text or integer and not decimal ? i haven't found it in mapserver documentation
Tonton
next the layer
LAYER
NAME "LabelParcelle.shp"
DATA "LabelParcelle.shp"
TYPE POINT
DEBUG 5
DUMP TRUE
LABELCACHE ON
METADATA
WMS_TITLE "LabelParcelle.shp"
"WMS_SRS" "EPSG:27572"
WFS_TITLE "LabelParcelle.shp"
"WFS_SRS" "EPSG:27572"
END
LABELITEM TXT
CLASS
STYLE
SYMBOL 7
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 0 0 0
END
LABEL
TYPE BITMAP
POSITION AUTO
SIZE MEDIUM
COLOR 0 0 0
End #LABEL
END
END #Layer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100604/c77b2bef/attachment-0001.html
