[mapserver-users] Support for Temporal and Thematic Dimensions in
WCS/WMS using NetCDF data
Matthias Müller
Matthias_Mueller at tu-dresden.de
Mon Jun 7 11:22:26 EDT 2010
Hi list!
Is there an elegant way to feed the UMN Mapserver with multi-temporal
(and maybe multithematic) data using netCDF as a datasource? If have
seen some services in the datafed portal
(http://www.datafed.net/DataLinks/OGC/DataFed_WMSServer.htm) that look
like a mapserver based WCS/WMS implementation.
A brief search produced a documentation using tile caches
(http://mapserver.org/ogc/wcs_format.html) as a workaround to load
multitemporal data. Is there any means to make the Mapserver use NetCDF
dimensions instead?
Cheers,
Matthias
