[mapserver-users] WMS layers order and copyright
Paco Regodón
mapserver at meteologica.es
Wed Jun 9 07:50:15 EDT 2010
It worked! Thanks!
I thought POSTLABELCACHE was only for scalebar since documentations says
"For use with embedded scalebars only."
You have saved me a lot of headaches.
Regards,
Paco
On 07/06/10 20:43, thomas bonfort wrote:
> POSTLABELCACHE at the layer level is the keyword you are looking for.
> regards,
> thomas
> On Mon, Jun 7, 2010 at 19:52, Rahkonen Jukka<Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>> This is what I have been using:
>> LAYER
>> NAME "copyright"
>> METADATA
>> "wms_title" "copyright"
>> END
>> STATUS DEFAULT
>> REQUIRES "[aerial_images]" # this text appears always with aerial images
>> in WMS
>> TYPE ANNOTATION
>> TRANSFORM ll #set the image origin to be lower left
>> FEATURE
>> POINTS
>> 85 -8 #set the offset from lower left position in pixels
>> END
>> TEXT " © 2010 aerial image provider" #this is your displaying text
>> END
>> CLASS
>> LABEL #defines the font, colors etc. of the text
>> FONT "arial"
>> TYPE TRUETYPE
>> SIZE 8
>> BUFFER 1
>> COLOR 200 100 50
>> BACKGROUNDCOLOR 255 255 255
>> FORCE TRUE
>> END
>> END
>> UNITS PIXELS #sets the units for the feature object
>> END
>> LAYER
>> NAME "copyright2"
>> METADATA
>> "wms_title" "copyright2"
>> END
>> STATUS DEFAULT
>> REQUIRES "![aerial_images]" #this layer appears with all WMS layers
>> except aerials
>> TYPE ANNOTATION
>> TRANSFORM lr #set the image origin to be lower right
>> FEATURE
>> POINTS
>> -75 -10 #set the offset
>> END
>> TEXT " © 2010 raster map provider" #this is your displaying text
>> END
>> CLASS
>> FONT "arial"
>> TYPE TRUETYPE
>> SIZE 8
>> BUFFER 1
>> COLOR 200 100 50
>> FORCE TRUE
>> END
>> END
>> END
>> -Jukka Rahkonen-
>> ________________________________
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>> Lähetetty: 7. kesäkuuta 2010 20:19
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] WMS layers order and copyright
>> Hi,
>> How can i force our copyright-logo layer to appear above the other layers
>> when serving WMS? Our logo/copyright layer is the last one in the mapfile,
>> and we're using "STATUS DEFAULT" but it seems mapserver ignores order and
>> draws this layer below the others.
>> We have no problems when caling mapserser cgi directly with its own
>> protocol, only when calling it using wms parameters.
>> Is it a bug?
>> Thanks,
>> Paco
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
