[mapserver-users] GetFeatureInfo from a JavaScript client
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Jun 10 06:14:31 EDT 2010
Mapserver does probably not receive a valid GetFeatureInfo request. Open the Apache access log file and see what is coming in. You can also test the request from browser.
-Jukka Rahkonen-
David Alda Fernandez de Lezea wrote:
> Hi folks,
> My situation: We've developed a GIS web viewer based on OpenLayers, with some particular configurations, and is located in a server, let's called "Server A", and we also have some other web applications that include this viewer to show some information and they're located in "Server B". The thing is that to avoid the cross-domain problem we've created an ASP script located in "Server B" that calls mapserver to receive the getfeatureinfo request, but when I try it in my web browser I get the following message:
> mapserv(): Web application error. Traditional BROWSE mode requires a TEMPLATE in the WEB section, but none was provided.
MapFile:
MAP
NAME "WMSSERVER"
STATUS ON
EXTENT 460000 4690000 610000 4820000 # Euskadi
SHAPEPATH "shapes_estaticos/"
FONTSET "misc/fonts/fonts.txt"
UNITS METERS
DEBUG ON
CONFIG "MS_ERRORFILE" "C:/ms4w/Apache/htdocs/MFD/tmp/ms_wms.log"
DEBUG 5
OUTPUTFORMAT
NAME gif
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
END
WEB
IMAGEPATH "C:/ms4w/Apache/htdocs/MFD/tmp/"
IMAGEURL "tmp/"
METADATA
"wms_name" "IKT WMS Server"
"wms_server_version" "1.1.1"
"wms_title" "Servidor WMS IKT"
"wms_onlineresource" "http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wms.map&"
"wms_srs" "EPSG:23030 EPSG:4326"
"wms_transparent" "true"
"wms_abstract" "Servicio de mapas WMS de IKT Nekazal Teknologia. Powered by Apache and UMN MapServer"
"wms_keywordlist" "IKT,Euskadi,Mapas Euskadi"
"wms_feature_info_mime_type" "application/vnd.ogc.gml"
"labelcache_map_edge_buffer" "-10"
END
END
PROJECTION
"init=epsg:23030"
END
LAYER
STATUS ON
CONNECTIONTYPE oraclespatial
CONNECTION "admcarto/admcarto at ORA10GEX"
NAME "RecintosSigpac"
PROJECTION
"init=epsg:23030"
END
DUMP TRUE
TYPE POLYGON
METADATA
"wms_title" "Recintos Sigpac 2009"
"wms_srs" "EPSG:23030"
"wms_name" "RecintosSigpac"
"wms_format" "image/gif"
END
MAXSCALE 25000
DATA "GEOMETRY FROM (SELECT * FROM GT_SIGPAC_REC_2010_ED50) USING UNIQUE gid SRID 82337" #todo el sigpac
CLASS
NAME "Recintos"
STYLE
OUTLINECOLOR 0 234 0
END
TEMPLATE "ms_template.html"
END
END
END
I've got "ms_template.html" created with the magic string.
What I'm doing wrong??
Thanks.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
