[mapserver-users] mapserver >= 5.6 and querys via php-mapscript
Sven Schroeter
schroeter at netgis.de
Thu Jun 10 09:01:49 EDT 2010
I'm still fighting with mapserver >= 5.6 and querys via php-mapscript.
My code for e.g. making a queryByRect works fine since I use resultsGetShape
instead of getShape for version 5.6:
//query
@$datQuery = $query_layer->queryByRect($qRect);
//number of objects
$resnum = $query_layer->getNumResults();
echo "number of objects: ".$resnum."<br>";
//if query success
if ($datQuery == MS_SUCCESS) {
//check ms version
if (ms_GetVersionInt() < 50600){
$query_layer->open();
//write table
echo '<table cellspacing="0" cellpadding="2" border="1" ><tr>';
for ($j=0; $j<$query_layer->getNumResults(); $j++) {
$result = $query_layer->getResult($j);
//check ms version
$shpobj = $query_layer->getShape($result->tileindex,$result->shapeindex);
else{
$shpobj =
$query_layer->resultsGetShape($result->shapeindex,$result->tileindex);
$si = $result->shapeindex;
$attr = $shpobj->values;
echo '<tr><td>'.$si.'</td>';
foreach($attr as $name=>$wert) {
echo '<td>'.$wert.'</td>';
echo '</tr>';
$shpobj->free();
//check ms version
$query_layer->close();
echo '</table>';
} // end success
My problem: using ms 5.6 the shapeindex ($result->shapeindex;) is only an
temporal arrayindex (0-x) and not the "real" shapeindex I get with
mapserverversions < 5.6.
How can I get the "real" shapindex of my shapes using ms 5.6? I need this
for pointing on single shapes in another program.
Thanks
Sven
