[mapserver-users] Re: automatically generate a layer's PROJECTION object for a mapfile?
Sumit Sharma sumit321 at hotmail.com
Fri Jun 11 10:09:54 EDT 2010
you would like to use OGR/OSR for this purpose. If you are using .NET you can
use swig wrappers. SpatialReference object can be used to create proj4
string from wkt.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/automatically-generate-a-layer-s-PROJECTION-object-for-a-mapfile-tp5167979p5168060.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
