[mapserver-users] performance problem
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Fri Jun 11 20:37:00 EDT 2010
What's speed like outside of OL? I mean, running shp2img.
In your OL code I wonder if ratio:3 might be causing *huge* image requests... With single tile mode I've have the best luck with ratio:1.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of fedesan [fedesanchez888 at gmail.com]
Sent: Friday, June 11, 2010 3:49 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] performance problem
I' having performance problems using postgreSQL 8.4 and mapserver 5.0.0 on a
4 cpu's sever with 16 GB RAM
I was using a mapfile with 10 layers but in order to find out the problem
now i'm using just one layer in a really basic mapfile.
gis.states_g table has only 24 records, one for each state in my country, so
is not a heavy query and i'm starting to think that is a mapserver
problem...is this a 5.0.0 known issue?
When i load the map (using openlayers) i notice that the 4 cpu's goes to
100% for a couple of seconds, and the same happens when i pan or when i zoom
in (this is even worse)
Can anyone give some tips about this? can somebody see an error that i'm
missing?
I'm not using fast-CGI, should i ??
**This is my mapfile and my html file:
MAP
NAME WMS_server
STATUS ON
SIZE 600 400
EXTENT -20000000 -7692209 2000000 -2212564
UNITS meters
IMAGECOLOR 216 243 249
OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE PC256
  EXTENSION "png"
END
WEB
  LOG /var/www/mapas/aen/educacion/mapfish/log_mapa_wms.log
  METADATA
    "wms_title"   "MEN WMS Server"
    "wms_srs"   "EPSG:900913"
  END
END
  PROJECTION
    "init=epsg:900913"
  END
  LAYER
    NAME "states"
    STATUS OFF
    CONNECTIONTYPE Postgis
    CONNECTION "user=fede password=fede dbname=men host=localhost"
    DATA "geom900913 from (select gid,geom900913 from gis.states_g) as foo
using unique gid using SRID=900913"
    TYPE POLYGON
    LABELMINSCALE 1500000
    TOLERANCE 2
      CLASS
      STYLE
        OUTLINECOLOR 156 156 156
      END
    END
    PROJECTION
      "init=epsg:900913"
    END
 END
END
HTML
 function init(){
            map = new
OpenLayers.Map('map',{projection:"EPSG:900913",maxExtent: new
OpenLayers.Bounds(-9186607, -8000000, -5948152, -1808791),maxResolution:
"auto",units: "m"});
            var wms = new OpenLayers.Layer.WMS(
            "wms",
"/cgi-bin/mapserv?map=path/mapa_wms.map&format=image/png&info_format=text/plain",
                    {layers:"states",transparent: true, format: "image/png"},
                        {isBaseLayer: true},
                        {singleTile: true, ratio: 3},
                        {gutter: 15}
       map.addLayers([wms]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.zoomToMaxExtent();
Thanks!!
Fede
View this message in context: http://osgeo-org.1803224.n2.nabble.com/performance-problem-tp5169667p5169667.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
