[mapserver-users] Re: Migration to MapServer
pcreso at pcreso.com
Sat Jun 12 17:28:14 EDT 2010
Essentially yes.
However, note that such an application may be retrieving data &/or code from a server via the LAN or internet, and may provide maps to either or both LAN or net clients. Not just data.
eg: your site may have a local copy of the OpenLayers code, or download on the fly from the OL website. Data may be from any local or remote server.
You can download data from places like OSM & store/use as local datasets, download on the fly, or download on the fly & cache locally.
You can use mapserver or other OGC compliant map serving applications such as Geoserver, Deegree, MapGuideOS, etc. Personally I prefer mapserver :-)
You can use OpenLayers natively or with wrappers providing additional functionality, such as
MapFish http://mapfish.org/
Geomoose http://geomoose.org/
to build your client, or use a framework which provides some such support built in such as
Drupal http://drupal.org/project/openlayers
GeoDjango http://code.djangoproject.com/wiki/GeoDjango
or one under development for Silverstripe.
You will also need tools for managing both raster & vector data to be served as maps, and to provide cacheing services to improve performance, and some CMS or framework to build & manage your application.
I suggest your toolset includes, but you should look at some such suite as your solution, not simply the map production components.
PostGIS for local vector data management
Tilecache for speeding up raster data rendering
mapserver as an OGC WMS/WFS providor
OpenLayers, either directly or through mapfish or Geomoose
HTH,
Brent Wood
--- On Sun, 6/13/10, yUser <yasirshoa at gmail.com> wrote:
> From: yUser <yasirshoa at gmail.com>
> Subject: [mapserver-users] Re: Migration to MapServer
> To: mapserver-users at lists.osgeo.org
> Date: Sunday, June 13, 2010, 8:49 AM
> Hello Till,
> Thanks for your reply.
> So based on your answer, this is what I infer:
> The solution is a combination of MapServer and OpenLayers.
> 1. First I find the data from www.openstreetmap.org (maybe
> it is ESRI
> ...have to check) , and then use that to display using
> MapServer.
> 2. Once map is rendered on the client, then OpenLayers will
> help with
> javascript part of drawing polylines on the map.
> Please advise if I am wrong in my understanding.
> Thanks.
> Aside: My main focus at is to have all of this within an
> LAN without any
> internet connection to begin with. Possibly have all the
> map data in a
> Server and then display that and use javascript on the
> client. I already
> have a working application using GoogleMaps API and I need
> to transfer it to
> the new solution. The other reason to have everything
> within LAN is to do
> Load Testing which is bit difficult with Google Maps
> considering that the
> load test might cause Google to block IP - assuming it as a
> DOS attack.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Migration-to-MapServer-tp5169931p5172726.html
> Sent from the Mapserver - User mailing list archive at
> Nabble.com.
