[mapserver-users] Function "queryByRect(rectObj rect)" not working
correctly
"tschobber tschöbbi"
tschobber at gmx.at
Tue Jun 15 05:59:29 EDT 2010
Hi mailing list,
I have a problem concerning the Mapserver function "queryByRect(rectObj rect)" or the function "getResult". The method returns the wrong results or rather shapes or something is wrong with the mapfile (see attachment). The strange part is that the amount of shapes selected is correct but the shapes selected aren't correct - important is that if I use the function "whichShapes" the shapes are selected correctly.
The first php code snippet shows a part of the method that gets wrong results. The second has the same effect but is using the function "whichShapes" and "nextShape" and the results are correct.
CODE1:
[PHP]
$map->queryByRect($oGeorefRect);//$oGeorefRect is a rectObj
$oLayer = $map->GetLayerByName($querylayer_in);//$querylayer_in = see mapfile layer "layer_xxx_100614_694d5fb11c67415"
$numResults = $oLayer->getNumResults();
for ($iRes=0; $iRes < $numResults; $iRes++) {
$oRes = $oLayer->getResult($iRes);
$oLayer->getFeature($oRes->shapeindex);
[/PHP]
CODE2:
[PHP]
$status = $oLayer->open();
$oLayer->whichShapes($oGeorefRect);
while($oShape = $oLayer->nextShape()) {
[/PHP]
What's the difference between those functions? Why is one working and the other not?
Thanks for answers.
Greetings,
Martin
GMX DSL: Internet-, Telefon- und Handy-Flat ab 19,99 EUR/mtl.
Bis zu 150 EUR Startguthaben inklusive! http://portal.gmx.net/de/go/dsl
MAP
EXTENT 100576.796875 265258 699423.203125 594238
FONTSET "../data/fonts/fonts.txt"
IMAGECOLOR 255 255 255
IMAGETYPE AGGA
SYMBOLSET "../includes/sys.sym"
SHAPEPATH "../data"
SIZE 700 385
STATUS ON
UNITS METERS
CONFIG MS_ERRORFILE "/tmp/ms_error.txt"
NAME "xxxxyyyy"
DEBUG 1
OUTPUTFORMAT
NAME "AGGA"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE "RGBA"
TRANSPARENT TRUE
FORMATOPTION "TRANSPARENT=ON"
END
OUTPUTFORMAT
NAME "gif"
MIMETYPE "image/gif"
DRIVER "GD/GIF"
EXTENSION "gif"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
OUTPUTFORMAT
NAME "png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
OUTPUTFORMAT
NAME "png24"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "RGB"
TRANSPARENT FALSE
FORMATOPTION "INTERLACE=OFF"
END
OUTPUTFORMAT
NAME "jpeg"
MIMETYPE "image/jpeg"
DRIVER "GD/JPEG"
EXTENSION "jpg"
IMAGEMODE "RGB"
TRANSPARENT FALSE
FORMATOPTION "QUALITY=100"
END
OUTPUTFORMAT
NAME "imagemap"
MIMETYPE "text/html"
DRIVER "imagemap"
EXTENSION "html"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
PROJECTION
"init=epsg:31297"
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS ON
STYLE HILITE
END
REFERENCE
COLOR -1 -1 -1
EXTENT 105000 265258 695000 594238
IMAGE "../img/keymap_0.png"
OUTLINECOLOR 255 0 0
SIZE 153 84
STATUS ON
MARKER 0
MARKERSIZE 0
MINBOXSIZE 3
MAXBOXSIZE 0
END
SCALEBAR
ALIGN CENTER
BACKGROUNDCOLOR 255 255 255
COLOR 50 50 50
INTERVALS 4
LABEL
SIZE TINY
TYPE BITMAP
BUFFER 0
COLOR 50 50 50
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
OUTLINECOLOR 50 50 0
POSITION LR
POSTLABELCACHE TRUE
SIZE 120 2
STATUS OFF
STYLE 0
UNITS KILOMETERS
END
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
MAXSCALEDENOM 3e+06
MINSCALEDENOM 100000
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
LAYER
CONNECTION "user=xxx password=xxx dbname=xxx host=localhost"
CONNECTIONTYPE POSTGIS
DATA "the_geom from gd_line_002"
NAME "xxx_01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE LINE
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 66 66 66
SIZE 1
SYMBOL 1
WIDTH 1
END
END
END
LAYER
DATA "the_geom from gd_line_001"
NAME "xxx01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE LINE
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 99 99 99
SIZE 2
SYMBOL 1
WIDTH 1
END
END
END
LAYER
DATA "the_geom from gd_line_004"
NAME "xxy01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE LINE
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 99 99 99
SIZE 2
SYMBOL 1
WIDTH 1
END
END
END
LAYER
DATA "the_geom from gd_line_007_3"
NAME "fluss01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 107 174 214
SIZE 1
SYMBOL 1
WIDTH 1
END
END
END
LAYER
DATA "the_geom from gd_poly_004"
NAME "xyy01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE POLYGON
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 189 215 231
OUTLINECOLOR 107 174 214
SYMBOL 0
WIDTH 1
END
END
END
LAYER
CLASSITEM "value"
DATA "the_geom from (SELECT gd_point_073.the_geom,gd_point_073.id as id, td_dim_geom.name as name,gd_point_073.oid,sum(td_theme_at_uba_ozon.value) as value FROM gd_point_073,td_theme_at_uba_ozon, td_dim_geom WHERE td_dim_geom.id = gd_point_073.id AND gd_point_073.id = td_theme_at_uba_ozon.geom AND (td_theme_at_uba_ozon.year = '2004' ) AND (td_theme_at_uba_ozon.uba_ozon_type = 'jmw' ) GROUP BY gd_point_073.id,gd_point_073.the_geom,td_dim_geom.name,gd_point_073.oid order by value desc) as foo using unique oid USING SRID=31297;"
METADATA
"LAYER_NAME" "layer_xxx_100614_694d5fb11c67415"
"DESCRIPTION" "OZON, Jahresmittelwert"
"GEOM_NAME" "gd_point_073"
"RESULT_FIELDS" "id"
"QUERY_TABLE" "td_theme_at_uba_ozon"
END
NAME "layer_xxx_100614_694d5fb11c67415"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TOLERANCE 10
TYPE POINT
UNITS METERS
CLASS
NAME "≤ 40"
EXPRESSION ([value] <= 40)
STYLE
ANGLE 360
COLOR 171 221 164
OUTLINECOLOR 30 30 30
SIZE 10
SYMBOL 1
WIDTH 1
END
TEMPLATE "xxx"
END
CLASS
NAME "> 40 - 50"
EXPRESSION ([value] > 40 and [value] <= 50)
STYLE
ANGLE 360
COLOR 171 221 164
SIZE 16
SYMBOL 1
WIDTH 1
END
TEMPLATE "xxx"
END
CLASS
NAME "> 50 - 60"
EXPRESSION ([value] > 50 and [value] <= 60)
STYLE
ANGLE 360
COLOR 171 221 164
SIZE 22
SYMBOL 1
WIDTH 1
END
TEMPLATE "xxx"
END
CLASS
NAME "> 60 - 70"
EXPRESSION ([value] > 60 and [value] <= 70)
STYLE
ANGLE 360
COLOR 171 221 164
SIZE 28
SYMBOL 1
WIDTH 1
END
TEMPLATE "xxx"
END
CLASS
NAME "> 70"
EXPRESSION ([value] > 70)
STYLE
ANGLE 360
COLOR 171 221 164
SIZE 34
SYMBOL 1
WIDTH 1
END
TEMPLATE "xxx"
END
END
LAYER
CLASSITEM "value"
DATA "the_geom from (SELECT gd_point_006.the_geom,gd_point_006.id as id, td_dim_geom.name as name,gd_point_006.oid,td_theme_at_topo_orte2.value as value FROM gd_point_006,td_theme_at_topo_orte2, td_dim_geom WHERE td_dim_geom.id = gd_point_006.id AND td_dim_geom.id = td_theme_at_topo_orte2.geom AND td_dim_geom.id = gd_point_006.id AND (td_theme_at_topo_orte2.orte_type = 'class1' ) order by value desc) as foo using unique oid USING SRID=31297;"
NAME "yyy01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE POINT
UNITS METERS
CLASS
NAME "Bedeutende Stadt im Ausland"
EXPRESSION "9"
STYLE
ANGLE 360
COLOR 200 200 200
SIZE 7
SYMBOL 1
WIDTH 1
END
END
CLASS
NAME "Bezirkshauptstadt"
EXPRESSION "2"
STYLE
ANGLE 360
COLOR 255 255 255
SIZE 7
SYMBOL 1
WIDTH 1
END
END
CLASS
NAME "Landeshauptstadt"
EXPRESSION "1"
STYLE
ANGLE 360
COLOR 255 255 255
SIZE 7
SYMBOL 2
WIDTH 1
END
END
END
LAYER
DATA "the_geom from gd_line_006"
NAME "xyx01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
OPACITY 75
TYPE LINE
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 99 99 99
SIZE 1
SYMBOL 1
WIDTH 1
END
END
END
LAYER
DATA "the_geom from (select gd_point_005_label.the_geom,gd_point_005_label.id,gd_point_005_label.oid,td_dim_geom.name from gd_point_005_label,td_dim_geom where gd_point_005_label.id = td_dim_geom.id) as foo using unique oid USING srid=31297"
LABELITEM "name"
NAME "blub"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE ANNOTATION
UNITS METERS
CLASS
NAME "class0"
LABEL
ANGLE 0.000000
ANTIALIAS TRUE
FONT "arial"
MAXSIZE 256
MINSIZE 4
SIZE 8
TYPE TRUETYPE
BUFFER 1
COLOR 0 0 0
FORCE FALSE
MINDISTANCE 1
MINFEATURESIZE -1
OFFSET 0 0
OUTLINECOLOR 255 255 255
PARTIALS FALSE
POSITION CC
END
END
END
LAYER
DATA "the_geom from (select gd_point_006.the_geom,gd_point_006.id,gd_point_006.oid,td_dim_geom.name from gd_point_006,td_dim_geom where gd_point_006.id = td_dim_geom.id) as foo using unique oid USING srid=31297"
LABELITEM "name"
NAME "blub01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
TYPE ANNOTATION
UNITS METERS
CLASS
NAME "class0"
LABEL
ANGLE 0.000000
ANTIALIAS TRUE
FONT "arial"
MAXSIZE 256
MINSIZE 4
SIZE 8
TYPE TRUETYPE
BUFFER 1
COLOR 0 0 0
FORCE FALSE
MINDISTANCE 1
MINFEATURESIZE -1
OFFSET 0 -9
PARTIALS FALSE
POSITION CC
END
END
END
LAYER
DATA "gd_raster_001.tif"
NAME "test01"
PROJECTION
"init=epsg:31297"
END
STATUS ON
OPACITY 15
TYPE RASTER
UNITS METERS
END
LAYER
DATA "the_geom from (select gd_point_073.the_geom,gd_point_073.id,gd_point_073.oid from gd_point_073,sys_select_data where gd_point_073.id = sys_select_data.geom and sys_select_data.id='any_100614_694d5fbc4fe2e9' ) as foo using unique oid USING srid=31297"
NAME "QUERY_xxx"
STATUS ON
OPACITY 70
TYPE POINT
UNITS METERS
CLASS
NAME "class0"
STYLE
ANGLE 360
COLOR 222 20 20
OUTLINECOLOR 100 0 0
SIZE 5
SYMBOL 1
WIDTH 1
END
END
END
END
