[mapserver-users] Changing map file parameters via a form or a URL EXPRESSION
stefanoferri stefano.ferri at stesurf.com
Mon Jun 21 06:20:40 EDT 2010
Hello everybody,
I tryed to use "Changing map file parameters via a form or a URL" and i had
success in modify for example the color of a layer in this way:
map.layer[cities].class[0].style[0]=COLOR+0+255+0,
but if i try to modify the EXPRESSION with this:
map.layer[cities].class[0]=EXPRESSION+([gid]<100)
i get this error:
"loadClass(): General error message. URL-based EXPRESSION configuration
failed pattern validation. msValidateParameter(): Regular expression error.
Parameter pattern validation failed. "
where do i wrong???
thanks for the help
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Changing-map-file-parameters-via-a-form-or-a-URL-EXPRESSION-tp5203714p5203714.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
