[mapserver-users] Changing map file parameters via a form or
a URL EXPRESSION
Paco Regodon
mapserver at meteologica.es
Mon Jun 21 09:38:39 EDT 2010
Maybe you should use runtime variable substitutions or maybe you need to
define validation patterns. Look at:
http://mapserver.org/cgi/runsub.html
You can call mapserver cgi passing a filter parameter. Something like
&myfilter=[gid]<100 and at layer's EXPRESSION use %myfilter%
Hope it helps.
Regards
Paco
On 21/06/10 12:20, stefanoferri wrote:
> Hello everybody,
> I tryed to use "Changing map file parameters via a form or a URL" and i had
> success in modify for example the color of a layer in this way:
> map.layer[cities].class[0].style[0]=COLOR+0+255+0,
> but if i try to modify the EXPRESSION with this:
> map.layer[cities].class[0]=EXPRESSION+([gid]<100)
> i get this error:
> "loadClass(): General error message. URL-based EXPRESSION configuration
> failed pattern validation. msValidateParameter(): Regular expression error.
> Parameter pattern validation failed. "
> where do i wrong???
> thanks for the help
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100621/95300cfb/attachment.html
