[mapserver-users] RE: MySQL data
Kent Morrison
KMorrison at advantrack.com
Wed Jun 23 14:29:37 EDT 2010
Thanks for the reply.
Below is the information used to generate tiles from TigerLine data for 1 county.. The tiles are generated but the perfomance is excutiatinly slow. This is a test set of data.
I guess what I need is some guidance on using mapserver with MySQL and how to optimize the performance. Ultimately my tables will contain millions of rows of data pulled from difference sources.
Versions:
Mysql: 5.1.41
Mapserver: using MS4W is version 3.0 beta 11 install
Access method: ? (see map file text below)
Spacial data: MySQL geometries
Map File:
MAP
IMAGETYPE AGG
SIZE 256 256
SHAPEPATH "/mapdata/shapefiles"
IMAGECOLOR 255 255 255
TRANSPARENT ON
FONTSET "../fonts/fonts.list"
EXTENT -95.909985 29.523624 -95.014496 30.110732
CONFIG PROJ_LIB "c:\ms4w\proj\nad\"
CONFIG MS_ERRORFILE "c:\ms4w\tmp\errors.txt"
DEBUG 2
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END #Outputformat
LAYER
DEBUG ON
NAME roads
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "MYSQL:revgeotest,host=tws1r-tj,user=*****,password=*****,port=3306,tables=tl_2009_48201_edges"
DATA "SELECT SHAPE as the_geom, fullname FROM tl_2009_48201_edges"
TYPE LINE
CLASS
STYLE
COLOR 0 0 0
WIDTH 8
END #Style
END #End Class
END #layer
END #Map
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Friday, June 18, 2010 8:39 AM
To: Kent Morrison; 'mapserver-users at lists.osgeo.org'
Subject: RE: MySQL data
Hi Kent: Probably need more information regarding:
- versions
- access method (are you using GDAL?)
- what type of spatial data (MySQL geometries vs points in x/y columns)
- etc...
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Kent Morrison [KMorrison at advantrack.com]
Sent: Thursday, June 17, 2010 2:13 PM
To: 'mapserver-users at lists.osgeo.org'
Subject: [mapserver-users] MySQL data
I have data stored in MySQL. When I configure the map file to pull from a small subset of the data, tiles are generated correctly. If I change the map file to point to the larger master table, map server returns "CGI Timeout". I dont't really want to breakdown the master data table into hundreds of smaller tables. I need additional informaiton and/or suggestions on how to get mapserver to work with millions of rows of data in MySQL.
Kent W. Morrison
Software Development Manager
Advanced Tracking Technologies, Inc.
6001 Savoy, Suite 600, Houston Texas 77036
(W) 713-353-6065 (C) 832-434-8175
<mailto:kmorrison at advantrack.com>
