[mapserver-users] ka-Map - Mapserver - Map display problem.
Jaisen
jaisuvyas at gmail.com
Sun Jun 27 22:33:56 EDT 2010
On 27 June 2010 22:33, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Jaisen,
> It would help to know what version of mapserver you are now running and what
> you were running before?
Now Version 5.6.3-1. The same available in the gfoss.itc.it repository.
Previously, No idea :-(
> You should also try something like:
> shp2img -m /path/to/your/mapfile.map -o junk.png
> and see if it reports any errors.
This doesn't report any error. I get a map in png file format.
> Recent versions of mapserver have had a change for security purposes which
> now require most mapserver support files to have well know tags as the first
> line(s) of the support file.
> http://mapserver.org/development/rfc/ms-rfc-56.html
> -Steve W
> Jaisen wrote:
>> Hi,
>> I have ka-Map implementations in my Debian (Lenny) system, and were
>> working pretty well. But after a system upgrade including mapserver,
>> nothing is displayed in map window. The Coords are shown as: x: NaN y:
>> NaN
>> And inside the folders (for example):
>> var/www/mykamap/htdocs/kacache/gmap/2500/Roads/def/t0/l0/meta
>> a blank text file is seen, named:
>> lock_-40_-40
It is not a blank file, as I stated before, Two dots (periods) are
there in the file.
Am attaching the report from one of my init.php file.
Any help?
>> Thanks in advance.
- ജയ്സെന് -
«´¨`·* . Jaisen . *..´¨`»
( `v´ )
`v´
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100628/274e3db3/ka-map_init_php_return.obj
