[mapserver-users] Re: OSM renderer with MapServer (christopher.schmidt@nokia.com)
Kent Morrison KMorrison at advantrack.com
Mon Jun 28 09:18:46 EDT 2010
I tried to get OSM running on MapServer using the instructions linked below and was only partially successful. It would render the coastlines but nothing else and there was no error messages in the debug file.
Kent
Message: 3
Date: Fri, 25 Jun 2010 20:25:19 +0200
From: "christopher.schmidt at nokia.com" <christopher.schmidt at nokia.com>
Subject: Re: [mapserver-users] OSM renderer with MapServer
To: <bfischer at houstoneng.com>
Cc: mapserver-users at lists.osgeo.org
Message-ID: <058B56D2-801E-4CDF-AF06-506432DFDD66 at nokia.com>
Content-Type: text/plain; charset="Windows-1252"
On Jun 25, 2010, at 1:52 PM, ext Brian Fischer wrote:
> Is there anyone working on a MapServer mapfile(s) to renderer OpenStreetMap data in the U.S.?  I?m interested in creating a mapfile that displays nice cartographic map for the roads and uses highway shields for the labels.  Ultimately turning this into a TMS using tilecache.  Or would people recommend sticking with Mapnik?s stylesheets to render the data into images?  I did a few searches and only came across this.  http://code.google.com/p/mapserver-utils/source/browse/trunk  I?m new to OSM data so just starting to explore options.
http://trac.osgeo.org/mapserver/wiki/RenderingOsmData leads to that location as well; This is the mapfile that is used for the map on the homepage:
  http://mapserver.org/
So it's probably a safe starting point.
Regards,
Christopher Schmidt
Nokia
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
End of mapserver-users Digest, Vol 29, Issue 43
