[mapserver-users] Re: OSM renderer with
MapServer (christopher.schmidt@nokia.com)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 28 10:16:21 EDT 2010
Kent Morrison wrote:
> Thanks for the quick feed back.
> I've got the map file.. Out sys admin ran it through a preprocessor on a linux machien for me.
> I thought the problem was/is probably a projection issue. I made the chaged all the "using srid=4326" to "using srid=900913" in all the DATA statements and changed all the PROJECTION statements from "init=epsg:4326" to "init=epsg:900913".
> Every thing renders perfectly now!
> If any windows user needs the map file I can email it to you.
Great Kent. This is a perfect time for you to edit that wiki page
(http://trac.osgeo.org/mapserver/wiki/RenderingOsmData) and update it
with any notes/hints that would have helped you...so other users can
benefit from your hard work.
Thanks.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
