[mapserver-users] ka-Map - Mapserver - Map display problem.
Daniel Morissette dmorissette at mapgears.com
Mon Jun 28 10:16:39 EDT 2010
Stephen Woodbridge wrote:
> Ok, this is good, then it is likely something has changed in the PHP
> mapscript. There is also a bug with the order of units which might be
> tripping you up. Maybe one of the PHP/mapscript gurus has an idea on
> what might be breaking ka-map on 5.6.3-1.
It's very possible that the issue may be related to the change in the
units array which affects 5.6.0 to 5.6.3 and will be fixed in 5.6.4:
http://trac.osgeo.org/mapserver/ticket/3173
If that's the case, then you could hack your local copy of ka-Map to
work around the issue as described here:
http://lists.maptools.org/pipermail/ka-map-users/2010-June/003977.html
Daniel
Daniel Morissette
http://www.mapgears.com/
