[mapserver-users] Fatal error: Call to a member function setSize()
on a non-object
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Tue Jun 29 08:27:33 EDT 2010
Hi there,
I am about to move my mapserver application from one (old) server to another (new) one. The old one was using mapserver 4.x, the new one the latest version. I copied the files over to the new server, eliminated the "dl("php_mapscript.so")", and in principal, I would have said, it should have worked.
But it doesn't...
It tells me "Fatal error: Call to a member function setSize() on a non-object". This happens on this line: $map -> setSize(900, 450);
The phpinfo file tells me that Mapscript is loaded correctly. So, what can it be?
Thanks for any suggestions!
Stef
Here is the somewhat more complete code:
// -- set map parameters --
// set paths
$map_path = GEO_ROOT_PATH."/../temp/";
$map = ms_newMapObj($map_path.$map_file);
// set maximal map-extent
$max_extent = ms_newrectObj();
$max_extent -> setextent(-180, -90, 180, 90);
// set extension for AJAX script in tpl file
if (($selectedRegion == "West Asia") && ($imgext == ""))
$imgext = "14 12 65 55";
if ($imgext == "") $imgext = "-180 -90 180 90";
$extent_dd = explode(" ", $imgext);
$tpl -> assign('mapExtent', $extent_dd[0].",".$extent_dd[2].",".$extent_dd[1]);
// set map size - either to selected size or to default size
if ($_POST["mapsize"])
$size = explode("x", $H_POST["mapsize"]);
$map -> set("width", $size[0]);
$map -> set("height", $size[1]);
else
