[mapserver-users] Problem with rectangular queries
"tschobber tschöbbi"
tschobber at gmx.at
Wed Jun 30 04:02:16 EDT 2010
Hi userlist,
could anyone help me on a mapserver issue? I've written a little php mapscript application (see complete code here http://pastebin.ca/1892318) that makes a rectangular query on a layer using the "querybyrect" method (method 1 --> see code) and addtional the same is done by using the "whichshapes" function (method 2). The problem is that method 1 (querybyrect) returns the wrong results whereas the results of method 2 are correct. Why is this? Do I need to define a real template file for method 1? If yes, how it has to look like to make the layer queryable the right way? Additional I should mention that the DATA for the layer is correct too.
Here's the mapfile for this application:
http://pastebin.ca/1892327
Thank you for any answers.
Greetings
GMX DSL: Internet-, Telefon- und Handy-Flat ab 19,99 EUR/mtl.
Bis zu 150 EUR Startguthaben inklusive! http://portal.gmx.net/de/go/dsl
