[mapserver-users] Re: Getfeatureinfo and MSsql 2008 server
afrozk at gmail.com
afrozk at gmail.com
Mon Mar 1 07:28:04 EST 2010
Dear Tamaz,
My mapserver version is 5.4.2 .
I ll upgrade and let u know the results.
Thnx a lot
Afroz
Sent from my BlackBerry® smartphone from du
-----Original Message-----
Date: Mon, 1 Mar 2010 13:02:56
To: Afroz Kannancheri<afrozk at gmail.com>
Cc: <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Re: Getfeatureinfo and MSsql 2008 server
I have an impression you encounter a problem which I've already fixed in
http://trac.osgeo.org/mapserver/ticket/3082.
Which version of the mapserver binaries have been used for testing?
I would suggest to download the latest from http://vbkto.dyndns.org/sdk/
Best regards,
Tamas
2010/3/1 Afroz Kannancheri <afrozk at gmail.com>
> Hi,
> Please find below the wkb hex string from the geom column
> 0xE61000000104070000005839B4C87606504091ED7C3F35CE4140AC1C5A643B0F4F40C976BE9F1A9F40401F85EB51B86E4F40E7FBA9F1D20D3F405A643BDF4F5D5040DD24068195233F402B8716D9CEDF5040F2D24D6210B840409A99999999B95040068195438BDC41405839B4C87606504091ED7C3F35CE414001000000020000000001000000FFFFFFFF0000000003
> Thanks
> Afroz
> On Mon, Mar 1, 2010 at 12:11 PM, Tamas Szekeres [via OSGeo.org] <[hidden
> email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4653039&i=0>
> > wrote:
>> Could you provide the query result (wkb hex string) displayed in the query
>> analyzer?
>> Best regards,
>> Tamas
>> 2010/3/1 Afroz Kannancheri <[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4653015&i=0>
>>> Dear Tamaz,
>>> This is the query that comes to the Sqlserver when I click on the polygon
>>> select convert(varchar(max), ID),convert(varchar(max),
>>> name),convert(varchar(max), flag1),convert(varchar(max),
>>> flag2),convert(varchar(max), flag3),geom from region1 where id = 218
>>> Executing the above query directly gives the correct values from the
>>> table.
>>> Thanks and regards
>>> Afroz
>>> View this message in context:
>>> http://n2.nabble.com/Getfeatureinfo-and-MSsql-2008-server-tp4631781p4652355.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>>_______________________________________________
>>> mapserver-users mailing list
>>> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4653015&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4653015&i=2>
> View this message in context: Re: Getfeatureinfo and MSsql 2008 server<http://n2.nabble.com/Getfeatureinfo-and-MSsql-2008-server-tp4631781p4653039.html>
> Sent from the Mapserver - User mailing list archive<http://n2.nabble.com/Mapserver-User-f1969211.html>at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100301/b1eb2244/attachment.html
