[mapserver-users] Re: Getfeatureinfo and MSsql 2008 server
Paul james pauljame at gmail.com
Tue Mar 2 14:33:54 EST 2010
Hi ...
I have the same error here using Getfeature and Mssql2008... Works fine with
Postgis connection ...
My last test was using Getfeature with a Point Layer... The message returned
was :
Content-type: application/vnd.ogc.se_xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
</ServiceExceptionReport>
No error reported using DEBUG mode...
The query generated was :
SELECT convert(varchar(max), oid),convert(varchar(max),
id),the_geom.STAsBinary(),convert(varchar(20), oid) from viw_test WHERE
the_geom.STIntersects(Geometry::STGeomFromText('POLYGON((-62.4340041752662
-11.1071026733531,-61.8187697837838 -11.1071026733531,-61.8187697837838
-10.4918682818707,-62.4340041752662 -10.4918682818707,-62.4340041752662
-11.1071026733531))',0)) = 1
That query executed in Analyser return the right result:
0x010100000000917EFB3A104FC061A6ED5F598925C0
Using CGI NQuery also doesnt work, returning :
Content-type: text/html
If you need more details, let me know...
Paul
On Tue, Mar 2, 2010 at 5:34 AM, Afroz Kannancheri <afrozk at gmail.com> wrote:
> Dear Tamas,
>  Heres the debug log obtained when i clicked on the polygon
> [Tue Mar 02 12:28:47 2010].113000 msMSSQL2008LayerOpen called
> datastatement:
> geom from region1 USING UNIQUE id USING SRID=4326
> [Tue Mar 02 12:28:47 2010].113000 MSMSSQL2008LayerOpen -- shared connection
> not available.
> [Tue Mar 02 12:28:47 2010].957000
> msConnPoolRegister(region1,server=3.254.254.34;uid=sa;pwd=pwd;database=map;Integrated
> Security=false,01E39FC0)
> [Tue Mar 02 12:28:47 2010].957000 msMSSQL2008LayerParseData: unique column
> id, srid='4326', geom_column_name = geom, table_name=region1
> [Tue Mar 02 12:28:47 2010].957000 msMSSQL2008LayerFreeItemInfo called
> [Tue Mar 02 12:28:47 2010].957000 in msMSSQL2008LayerGetItems  (find column
> names)
> [Tue Mar 02 12:28:48 2010].113000 msMSSQL2008LayerInitItemInfo called
> [Tue Mar 02 12:28:48 2010].113000 msMSSQL2008LayerWhichShapes called
> [Tue Mar 02 12:28:48 2010].113000 query_string_temp:SELECT
> convert(varchar(max), ID),convert(varchar(max), name),convert(varchar(max),
> flag1),convert(varchar(max), flag2),convert(varchar(max),
> flag3),geom.STAsBinary(),convert(varchar(20), id) from region1 WHERE
> geom.STIntersects(Geometry::STGeomFromText('POLYGON((55.4843749962207
> -4.59960928778372,56.5390624973545 -4.59960928778372,56.5390624973545
> -3.54492178664993,55.4843749962207 -3.54492178664993,55.4843749962207
> -4.59960928778372))',4326)) = 1
> [Tue Mar 02 12:28:48 2010].394000 msMSSQL2008LayerClose datastatement: geom
> msConnPoolRelease(region1,server=3.254.254.34;uid=sa;pwd=pwd;database=map;Integrated
> msConnPoolClose(server=3.254.254.34;uid=sa;pwd=pwd;database=map;Integrated
> [Tue Mar 02 12:28:48 2010].410000 freeLayer(): freeing layer at 01E15180.
> Thnx
> Afroz
> http://n2.nabble.com/Getfeatureinfo-and-MSsql-2008-server-tp4631781p4659685.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100302/9fce8319/attachment.html
