[mapserver-users] getmap request with SLD failing after upgrade
to 5.6.0
DeDuikertjes
DeDuikertjes at xs4all.nl
Wed Mar 3 02:30:02 EST 2010
Thank you,
I've did as you said, but can't get a clue on what's going on.
The error file shows:
[Wed Mar 3 08:21:29 2010].677158 msApplySLD(): Map file after SLD was
applied
/var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map[Wed
Mar 3 08:21:29 2010].731599 msyyparse(): Expression parser error.
syntax error
[Wed Mar 3 08:21:29 2010].731628 msEvalExpression: Expression parser
error. Failed to parse expression: NL.IMRO.0184.BA127909736-00 =
NL.IMRO.0184.EP127818521-00
[Wed Mar 3 08:21:29 2010].731649 msyyparse(): Expression parser error.
syntax error
And a lot more of these expression errors.
Then followed by
[Wed Mar 3 08:21:29 2010].745454 msDrawMap(): Layer 0 (query_vlak), 0.029s
[Wed Mar 3 08:21:29 2010].747286 msDrawMap(): Layer 1 (query_lijn), 0.002s
[Wed Mar 3 08:21:29 2010].749832 msDrawMap(): Layer 2 (query_punt), 0.003s
[Wed Mar 3 08:21:29 2010].750760 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Mar 3 08:21:29 2010].750771 msDrawMap() total time: 0.046s
[Wed Mar 3 08:21:29 2010].999507 msSaveImage() total time: 0.249s
[Wed Mar 3 08:21:29 2010].999706 mapserv request processing time
(msLoadMap not incl.): 0.336s
[Wed Mar 3 08:21:29 2010].999723 msFreeMap(): freeing map at 0x81bf400.
What is going wrong?
MArco
Yewondwossen Assefa schreef:
> Hi There,
> One way to debug would be to set your map file in debug, something
> like this:
> CONFIG "MS_ERRORFILE" "f:/msapps/gmap-ms40/htdocs/gmap.log"
> DEBUG 5
> and check the logs. It should show you the map file after the sld has
> been applied. That might give a hint on what went wrong.
> best regards,
> DeDuikertjes wrote:
>> Hi List,
>> Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0 (FGS).
>> I use it as a WMS. Everything looks fine, but I've one anoying problem:
>> When I do a getmap-request with an SLD I get an empty image back, while
>> 5.1-dev gives me a proper result.
>> Other getmap requests work fine.
>> I tested this several times by swapping the old mapserv executable with
>> the new one.
>> an example of a getmap request which fails on 5.6.0 and succeeds in
>> 5.1-dev is:
>> https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-0201.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyledLayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3Egeoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3
>> E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800&HEIGHT=841
>> any help greatly appreciated, MArco
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
