[mapserver-users] getmap request with SLD failing after upgrade to 5.6.0
Bart van den Eijnden bartvde at osgis.nl
Wed Mar 3 02:41:41 EST 2010
Hi Marco,
Mapserver has saved a temporary MAP file, please open it up and check if something is wrong in there, or post the LAYER definition to the  mailing list.
> /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map
Best regards,
Bart
On Mar 3, 2010, at 8:30 AM, DeDuikertjes wrote:
> Thank you,
> I've did as you said, but can't get a clue on what's going on.
> The error file shows:
> [Wed Mar  3 08:21:29 2010].677158 msApplySLD(): Map file after SLD was applied /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map[Wed Mar  3 08:21:29 2010].731599 msyyparse(): Expression parser error. syntax error
> [Wed Mar  3 08:21:29 2010].731628 msEvalExpression: Expression parser error. Failed to parse expression: NL.IMRO.0184.BA127909736-00 = NL.IMRO.0184.EP127818521-00
> [Wed Mar  3 08:21:29 2010].731649 msyyparse(): Expression parser error. syntax error
> And a lot more of these expression errors.
> Then followed by
> [Wed Mar  3 08:21:29 2010].745454 msDrawMap(): Layer 0 (query_vlak), 0.029s
> [Wed Mar  3 08:21:29 2010].747286 msDrawMap(): Layer 1 (query_lijn), 0.002s
> [Wed Mar  3 08:21:29 2010].749832 msDrawMap(): Layer 2 (query_punt), 0.003s
> [Wed Mar  3 08:21:29 2010].750760 msDrawMap(): Drawing Label Cache, 0.000s
> [Wed Mar  3 08:21:29 2010].750771 msDrawMap() total time: 0.046s
> [Wed Mar  3 08:21:29 2010].999507 msSaveImage() total time: 0.249s
> [Wed Mar  3 08:21:29 2010].999706 mapserv request processing time (msLoadMap not incl.): 0.336s
> [Wed Mar  3 08:21:29 2010].999723 msFreeMap(): freeing map at 0x81bf400.
> What is going wrong?
> MArco
> Yewondwossen Assefa schreef:
>> Hi There,
>> One way to debug would be to set your map file in debug, something like this:
>> CONFIG  "MS_ERRORFILE" "f:/msapps/gmap-ms40/htdocs/gmap.log"
>> DEBUG 5
>> and check the logs. It should show you the map file after the sld has been applied. That might give a  hint on what went wrong.
>> best regards,
>> DeDuikertjes wrote:
>>> Hi List,
>>> Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0 (FGS).
>>> I use it as a WMS. Everything looks fine, but I've one anoying problem:
>>> When I do a getmap-request with an SLD I get an empty image back, while
>>> 5.1-dev gives me a proper result.
>>> Other getmap requests work fine.
>>> I tested this several times by swapping the old mapserv executable with
>>> the new one.
>>> an example of a getmap request which fails on 5.6.0 and succeeds in
>>> 5.1-dev is:
>>> https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-0201.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyledLayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3Egeoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3
>>> E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800&HEIGHT=841
>>> any help greatly appreciated, MArco
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
