[mapserver-users] getmap request with SLD failing after upgrade to 5.6.0
Yves Jacolin yves.jacolin at camptocamp.com
Wed Mar 3 03:37:53 EST 2010
I guees this is this part which run an error:
error. Failed to parse expression: NL.IMRO.0184.BA127909736-00 =
NL.IMRO.0184.EP127818521-00
Try to change :
 EXPRESSION ([geoidn] = NL.IMRO.0184.EP127818521-00)
in :
 EXPRESSION ([geoidn] = "NL.IMRO.0184.EP127818521-00")
Regards,
Y.
Le mercredi 03 mars 2010 09:01:04, Bart van den Eijnden a écrit :
> It seems Mapserver does not treat your column as a character column, try
> using the following METADATA on your source layer (so not in the temporary
> MAP file):
> "gml_geoidn_type" "Character"
> Best regards,
> Bart
> On Mar 3, 2010, at 8:52 AM, DeDuikertjes wrote:
> > Bart,
> > Thanks for the suggestion. I've opened up the temporary MAP file. A layer
> > definition from this file is (there are a LOT more like that):
> > LAYER
> >   CONNECTION "host=xxxxxxx user=xxxxx dbname=xxxxxxx"
> >   CONNECTIONTYPE POSTGIS
> >   DATA 'tc_punt_geometry from "NL.IMRO.0184.Zeewijkfase4-0201_aggregated"
> > using unique oid using srid=28992' DUMP TRUE
> >   GROUP "query"
> >   METADATA
> >     "wms_srs" "EPSG:28992 EPSG:900913 EPSG:4326"
> >     "ows_feature_id"  "geoidn"
> >     "ows_group_title" "query"
> >     "ows_extent"      "170861.5122 520007.0618 171570.1698 520546.6582"
> >     "gml_exclude_items"
> > "tc_multi_geometry,tc_vlak_geometry,tc_lijn_geometry,tc_punt_geometry"
> > "ows_title"       "query_punt"
> >     "gml_include_items"       "all"
> >     "ows_exclude_items"       "all"
> >   END
> >   NAME "query_punt"
> >   PROCESSING "CLOSE_CONNECTION=DEFER"
> >   PROJECTION
> >     "init=epsg:28992"
> >   END
> >   STATUS ON
> >   TEMPLATE "query.html"
> >   TYPE POLYGON
> >   UNITS METERS
> >   CLASS
> >     NAME "Unknown"
> >     STYLE
> >       ANGLE 360
> >       COLOR 255 0 255
> >       OPACITY 40
> >       SIZE 2
> >       SYMBOL "sld_line_symbol"
> >       WIDTH 1
> >     END
> >     STYLE
> >       ANGLE 360
> >       COLOR 255 0 255
> >       OPACITY 40
> >       SYMBOL 0
> >       WIDTH 1
> >     END
> >     STYLE
> >       ANGLE 360
> >       OPACITY 40
> >       OUTLINECOLOR 255 0 255
> >       SIZE 2
> >       WIDTH 1
> >     END
> >   END
> > END
> > MArco
> > Bart van den Eijnden schreef:
> >> Hi Marco,
> >> Mapserver has saved a temporary MAP file, please open it up and check if
> >> something is wrong in there, or post the LAYER definition to the
> >> mailing list.
> >>> /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_chec
> >>>k/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map
> >> Best regards,
> >> Bart
> >> On Mar 3, 2010, at 8:30 AM, DeDuikertjes wrote:
> >>> Thank you,
> >>> I've did as you said, but can't get a clue on what's going on.
> >>> The error file shows:
> >>> [Wed Mar  3 08:21:29 2010].677158 msApplySLD(): Map file after SLD was
> >>> applied
> >>>k/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map[Wed Mar  3 08:21:29
> >>> 2010].731599 msyyparse(): Expression parser error. syntax error [Wed
> >>> Mar  3 08:21:29 2010].731628 msEvalExpression: Expression parser error.
> >>> NL.IMRO.0184.EP127818521-00 [Wed Mar  3 08:21:29 2010].731649
> >>> msyyparse(): Expression parser error. syntax error And a lot more of
> >>> these expression errors.
> >>> Then followed by
> >>> [Wed Mar  3 08:21:29 2010].745454 msDrawMap(): Layer 0 (query_vlak),
> >>> 0.029s [Wed Mar  3 08:21:29 2010].747286 msDrawMap(): Layer 1
> >>> (query_lijn), 0.002s [Wed Mar  3 08:21:29 2010].749832 msDrawMap():
> >>> Layer 2 (query_punt), 0.003s [Wed Mar  3 08:21:29 2010].750760
> >>> msDrawMap(): Drawing Label Cache, 0.000s [Wed Mar  3 08:21:29
> >>> 2010].750771 msDrawMap() total time: 0.046s [Wed Mar  3 08:21:29
> >>> 2010].999507 msSaveImage() total time: 0.249s [Wed Mar  3 08:21:29
> >>> 2010].999706 mapserv request processing time (msLoadMap not incl.):
> >>> 0.336s [Wed Mar  3 08:21:29 2010].999723 msFreeMap(): freeing map at
> >>> 0x81bf400.
> >>> What is going wrong?
> >>> MArco
> >>> Yewondwossen Assefa schreef:
> >>>> Hi There,
> >>>> One way to debug would be to set your map file in debug, something
> >>>> like this: CONFIG  "MS_ERRORFILE"
> >>>> "f:/msapps/gmap-ms40/htdocs/gmap.log"
> >>>> DEBUG 5
> >>>> and check the logs. It should show you the map file after the sld has
> >>>> been applied. That might give a  hint on what went wrong.
> >>>> best regards,
> >>>> DeDuikertjes wrote:
> >>>>> Hi List,
> >>>>> Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0
> >>>>> (FGS). I use it as a WMS. Everything looks fine, but I've one anoying
> >>>>> problem:
> >>>>> When I do a getmap-request with an SLD I get an empty image back,
> >>>>> while 5.1-dev gives me a proper result.
> >>>>> Other getmap requests work fine.
> >>>>> I tested this several times by swapping the old mapserv executable
> >>>>> with the new one.
> >>>>> an example of a getmap request which fails on 5.6.0 and succeeds in
> >>>>> 5.1-dev is:
> >>>>> https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/
> >>>>>data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-02
> >>>>>01.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMa
> >>>>>p&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fx
> >>>>>ml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyled
> >>>>>LayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld
> >>>>>%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3
> >>>>>Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%
> >>>>>3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3E
> >>>>>geoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127
> >>>>>818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fo
> >>>>>gc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACs
> >>>>>sParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%
> >>>>>3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssP
> >>>>>arameter%3
> >>>>> E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D
> >>>>>%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParamet
> >>>>>er%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csl
> >>>>>d%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParamet
> >>>>>er%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALin
> >>>>>eSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stro
> >>>>>ke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20na
> >>>>>me%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACss
> >>>>>Parameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3
> >>>>>C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C
> >>>>>%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedL
> >>>>>ayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625
> >>>>>312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800
> >>>>>&HEIGHT=841 any help greatly appreciated, MArco
> >>>>> _______________________________________________
> >>>>> mapserver-users mailing list
> >>>>> mapserver-users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Yves Jacolin
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 26 57 98
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
