[mapserver-users] DXF layer definition in mapfile
Thu Mar 4 11:06:50 EST 2010
Dejan Gambin wrote:
> Hi,
> Since DXF driver has been made, I would like to show a DXF file on the map. Is this possible? What syntax do I have to use to make it work?
> I have tried defining it similar to dgn syntax, but it doesn't work. I get: "msOGRFileOpen(): Open failed for OGR connection in layer `layer_name'.  File not found or unsupported format.".
> ogrinfo works fine on this file. For example:
> My layer definition looks like this:
> LAYER # dxf
>   NAME         "layer_name"
>   GROUP 	   "group_name"
>   STATUS       ON
>   TYPE         LINE
>   METADATA
>     "DESCRIPTION" "Description"
>   END
>   CONNECTIONTYPE OGR
>   CONNECTION "/Library/WebServer/Documents/demodata/test.dxf"
>   DATA "0"
>   STYLEITEM "AUTO"
>   CLASS
>     NAME "All"
>   END
>   PROJECTION
>     "init=epsg:31275"
>   END
> END
Dejan,
I suspect you have more than one gdal/ogr on your system and MapServer
isn't using the new one.  Because DXF files are represented as having only
one layer you don't normally need a DATA statement to select the layer.
One example of mine looks like:
MAP
STATUS ON
EXTENT 0 80 120 160
SIZE 600 400
FONTSET "/home/warmerda/mapserver/fonts.lst"
IMAGECOLOR 0 0 128
IMAGETYPE png
LAYER
   NAME shppoly
   TYPE line
   CONNECTIONTYPE OGR
   CONNECTION "assorted.dxf"
   STATUS default
   STYLEITEM "AUTO"
   CLASS
     NAME "work"
   END
END
LAYER
   NAME textstuff
   TYPE annotation
   CONNECTIONTYPE OGR
   STATUS default
   STYLEITEM "AUTO"
   CLASS
     NAME "work"
   END
END
END
