[mapserver-users] Mapserver in ubuntu: not displaying map
ashka fernando
ashka.akash at gmail.com
Fri Mar 5 02:58:02 EST 2010
Dear Alan,
yes . the issue was with the imageurl.
WEB
TEMPLATE "/var/www/tutorial/example2-1.html"
IMAGEPATH "/var/www/tutorial/tmp/"
IMAGEURL "http://localhost/tutorial/tmp/"
END
now it works !
I was worrying about the permission , as not familiar with ubuntu and failed
to identify actual error.
Thanks a lot
Ashka
On Thu, Mar 4, 2010 at 6:48 AM, Alan Boudreault <aboudreault at mapgears.com>wrote:
> ashka,
> Have you taken a look at the image url (in the browser) ? Since the image
> path is "/var/www/tutorial/tmp" and "/var/www/" is already available from
> the web (with the default apache configuration).... the image url of your
> image should be something like "
> http://localhost/tutorial/tmp/EX2.1_12675266704111.png". The image url can
> be configured in the mapfile: http://mapserver.org/mapfile/web.html
> Alan
> ashka fernando wrote:
>> Dear all,
>> I am trying to run Mapserver in Ubuntu Karmic Koala. I have successfully
>> used Mapserver in windows and now want to migrate to ubuntu . But I'm very
>> much new to ubuntu and struggle to get the work done smoothly.
>> The Mapserver and Apache both are running ,works fine as localhost.
>> I can get a map in map mode ( based on map server tutorial examples) but
>> failed to get the map display in the browse mode.
>> There is no error massage and the web template is displaying with all
>> components except the map image. The map images are created inside the tmp
>> folder however they are not displayed in the template interface.
>> I think its due to permission issues but failed to solve it, even after
>> going through forums.
>> The locations of the templete and map files are /var/www/tutorial
>> The location of the image path /var/www/tutorial/tmp
>> For /var/www/tutorial/tmp permissions are as follows
>> drwxrwsr-x 2 gisuser www-data 4096 2010-03-02 16:14 tmp
>> when the new map images are created by the mapserver , the image files
>> have permissions like this
>> -rwxrwxr-- 1 www-data www-data 11686 2010-03-02 16:14
>> Why doesn't these map images are not displaying in the web template file?
>> Can anyone suggest a way to solve this issue?
>> This may be rather relate to running Apache in Ubuntu. As failed to get
>> any help from ubuntu forum, compelled to ask help from you all.
>> appreciate any help .
>> ashka
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Alan Boudreault
> Mapgears
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100305/83d8111a/attachment-0001.html
