[mapserver-users] More upgrade problems
DeDuikertjes DeDuikertjes at xs4all.nl
Fri Mar 5 14:22:40 EST 2010
Daniel,
Thank you for your answer.
"iconv -l" tells me UTF-8 is supported.
My data comes from postgis.
If I look in the postgis database it tells me it's encoded in UTF8.
If I make a database with:
CREATE DATABASE "ppa_test_database"
  WITH OWNER = xxxxx
       ENCODING = 'UTF-8'
       CONNECTION LIMIT = -1;
postgis tells me the database ppa_test_database is encoded in UTF8 and
not UTF-8.
So apparently postgis wants to state UTF8 and iconv wants to hear UTF-8.
Is there any way around this?
MArco
Daniel Morissette schreef:
> <div class="moz-text-flowed" style="font-family:
> -moz-fixed">DeDuikertjes wrote:
>> It gives me a LOT of errors like:
>> [Thu Mar  4 15:14:05 2010].903727 msGetEncodedString(): Unknown
>> identifier. Encoding not supported by libiconv (UTF8).
>> Searching and reading up on this I couldn't find a reason why things
>> work in 5.1-dev and work not in 5.4.2.
> Maybe the difference is caused by a different version of iconv being
> used by the new build?
> Anyway, the error message says "encoding UTF8 not supported". I
> believe the identifier should be "UTF-8" and not "UTF8".
> FYI, "iconv -l" can be used at the command-line to list the encodings
> supported by your version of libiconv.
> Daniel
