[mapserver-users] [SOLVED] More upgrade problems
DeDuikertjes
DeDuikertjes at xs4all.nl
Sat Mar 6 12:44:04 EST 2010
Daniel,
Thank You !
It is the mapfile indeed. The LABEL block stated UTF8.
Changing that to UTF-8 solved the problem.
MArco
Daniel Morissette schreef:
> <div class="moz-text-flowed" style="font-family:
> -moz-fixed">DeDuikertjes wrote:
>> postgis tells me the database ppa_test_database is encoded in UTF8
>> and not UTF-8.
>> So apparently postgis wants to state UTF8 and iconv wants to hear UTF-8.
>> Is there any way around this?
> I don't think MapServer reads the encoding value from PostGIS, it gets
> it from the ENCODING parameter in your LABEL block in your mapfile.
> Make sure the ENCODING value in your mapfile are all valid (one of
> them must be using UTF8 instead of UTF-8).
> Daniel
