[mapserver-users] shapeObj constructor
Prateek Khatri
khatriprateek at gmail.com
Sun Mar 7 10:41:46 EST 2010
Hi Tamas,
Thanks for the reply. I tried that also but it gives error because
MS_SHAPE_TYPE.MS_SHAPE_LINE is not of type int.
On Sun, Mar 7, 2010 at 8:48 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> You must specify the desired shape type as the argument which can be:
> MS_SHAPE_TYPE.MS_SHAPE_NULL
> MS_SHAPE_TYPE.MS_SHAPE_POINT
> MS_SHAPE_TYPE.MS_SHAPE_POLYGON
> Best regards,
> Tamas
> 2010/3/7 mrityunjay <khatriprateek at gmail.com>
>> I'm using mapscript in java. The shapeObj constructor requires a variable
>> of
>> type int. The available options in the mapscript constants are:
>> MS_SHP_POINTZ, MS_SHP_ARCZ, MS_SHP_POLYGONZ, MS_SHP_MULTIPOINTZ
>> MS_SHP_POINTM, MS_SHP_ARCM, MS_SHP_POLYGONM, MS_SHP_MULTIPOINTM
>> Which one should I use for shapeObj for line type geometry feature?
>> Actually
>> using MS_SHP_POLYGONZ gives error for the layer of type line.
>> Thanks
>> View this message in context:
>> http://n2.nabble.com/shapeObj-constructor-tp4690347p4690347.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Regards
Prateek Khatri
Fourth Year Undergraduate
Computer Science and Engineering
Indian Institute of Technology Bombay
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100307/30b187ad/attachment.html
