[mapserver-users] LABEL-formatting options
Lars Lingner
ml at lingner.eu
Tue Mar 9 12:46:00 EST 2010
Stephan Holl schrieb:
> Hello mapservers,
> we are using MapServer for visualizing shapefiles with double entries
> inside.
> Mainly this are contour-lines from waterdepth. The double values have
> 32 decimal places and mapserver tries to render them _all_ along a
> contourline.
> This does not look nice...
> Is there an option to trim the values with a dedicated
> mapfile-parameter, e.g. where a prinft-syntax can be used to format the
> values?
> The shapefiles are generated automatically so adding another column with
> trunc()ed or round()ed values is no option.
> Are there any options to format label-values/strings? I have not found
> anything in the docs.
AFAIK there isn't a trim/cut function.
If the numbers have the same ending you could define them as WARP
character and they would be replaced by a line break.
Would mapscript help you here?
Or to make things more complicated: Couldn't you write the the
shapefiles into an database? Then you could use trim/cut the value
within your sql statement.
Lars
