[mapserver-users] LABEL-formatting options
Stephan Holl stephan.holl at intevation.de
Wed Mar 10 02:59:53 EST 2010
Hello Steve,
"Lime, Steve D (DNR)" <Steve.Lime at state.mn.us>, [20100309 - 22:35:51]
> Hi Stephan: This is an increasingly asked question but at the moment
> I don't have a good solution or workaround, it's just not possible at
> the moment. There's a ticket already filed on the subject and it will
> be addressed in 6.0.
> Are you in a position where you could apply a patch to deal with the
> problem if one were available?
Sure I am, I would be happy to test a patch and give feedback.
I will CC myself to the ticket[1], hopefully I have found the right
one, there is another one with a similar topic[2] which seems only
apply for templating.
Anyway, thanks for your response, I am awaiting your patches for
testing :)
Cheers
	Stephan
[1] http://trac.osgeo.org/mapserver/ticket/60
[2] http://trac.osgeo.org/mapserver/ticket/1634
> Hello mapservers,
> we are using MapServer for visualizing shapefiles with double entries
> inside.
> Mainly this are contour-lines from waterdepth. The double values have
> 32 decimal places and mapserver tries to render them _all_ along a
> contourline.
> This does not look nice...
> Is there an option to trim the values with a dedicated
> mapfile-parameter, e.g. where a prinft-syntax can be used to format
> the values?
> The shapefiles are generated automatically so adding another column
> with trunc()ed or round()ed values is no option.
> Are there any options to format label-values/strings? I have not found
> anything in the docs.
> TIA
>         Stephan
> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> 3663 Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR
> B 18998 Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr.
> Jan-Oliver Wagner
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100310/473613b9/signature.bin
