[mapserver-users] runtime substitution not working
Ben Madin
lists at remoteinformation.com.au
Sat Mar 13 19:25:37 EST 2010
G'day Brent,
It might not matter, but you have double %% in the DATA statement you have passed,
and for whatever reason - I recevied advice from this list or OpenLayers list - I have all my variable names capitalised in the query:
WHERE transferdate >= '%STARTDATE%' AND transferdate <= '%ENDDATE%'
AND line_geom IS NOT NULL
AND sourceshire NOT LIKE destinationshire
AND sourceshire LIKE '%SOURCESHIRE%'
So I hope these might help if Steve's solution didn't
cheers
Ben
On 13/03/2010, at 24:00 , mapserver-users-request at lists.osgeo.org wrote:
> I'm obviously doing something wrong, but can't see what it is... I have a Postgis table of species occurences & I want to pass a variable to the mapfile to select which speciesusing runtime substitution.
> The relevant DATA statement (joining species in the catch to locations in the station) in the mapfile is:
> DATA "startp from (select c.id, s.startp, s.trip_code,
> s.station_no, c.species,
> c.weight
> from t_station s, catch c
> where s.station_no=c.station_no
> and c.species ilike '%%spp%%')
> as myquery
> using unique id using srid=4326"
> The query works in Postgis & in the mapfile (via QGIS) when I hard code the %spp% (eg, to 'TAR')
> I'm using QGIS to open the layer, with the URL:
> http://wms-dev/cgi-bin/mapserv?map=/srv/www/htdocs/mapdata/catch.map&spp=TAR
> QGIS appends the request type, etc & it works with the hard coded "spp"
> The mapfile also has:
> METADATA
> "wms_title" "species"
> "wms_srs" "epsg:4326"
> "wfs_title" "species"
> "wfs_version" "1.0.0"
> "wfs_typename" "species"
> "wfs_request_method" "GET"
> "wfs_service" "WFS"
> "spp_validation_pattern" '^[A-Z0-9][A-Z0-9][A-Z0-9]$'
> END
> The version I'm running is MapServer version 5.4.1
> (so no default supported)
> The docs say I can use shp2img to test runtime substitution in a mapfile, but I can't see how to invoke the substitution with the equivalent of a spp=TAR statement to test this.
> Any suggestions?
> Thanks
> Brent Wood
